05-31-2008, 05:57 AM | #1 |
rrroadburn
20
Rep 243
What's the best launch technique?
There has been a lot of discussion of 0-60 times for the 135, but how are drivers getting them?
I'm curious: what rpm's at launch, pop or slip the clutch, etc. I haven't had to embarrass a Shelby Mustang yet, but you never know when the need will arise. I could find out through trial-and-error, I suppose, but in my case that usually involves so much error....
CXXXVi |
05-31-2008, 07:28 AM | #2 |
Rep 172
In the May issue of Road & Track they wre getting 4.8 second 0-60. Their technique was traction control off, 4000 RPM and release clutch smoothly. There should be just a little tire slip. I don't have mine for 2 more weeks, so I can't confrim how this works - and then there's that break in thing.
05-31-2008, 11:15 AM | #4 | |
Tech. Certified
11
Rep 309
http://www.1addicts.com/forums/showt...unch+automatic |
05-31-2008, 06:29 PM | #5 |
rrroadburn
20
Rep 243
4,000 seems like a lot of rpms, given how much torque this engine has. Won't it just sit there & smoke the tires? Especially with only the e-diff functioning?
Plus, in another thread, I ran across this quote from a 135 owner with an automatic: "Launch at 1800rpms on a dry sunny day on decent ground and I don't see any reason a 4.7-4.8 0-60 is not possible." Somebody's got it wrong. I'm wondering if anyone who doesn't work for a magazine has tried an actual, real-world 0-60 run, and how they did it....
CXXXVi |
05-31-2008, 06:36 PM | #6 |
Tech. Certified
11
Rep 309
I must have missed something, where are you reading 4000 rpms? The thread I posted mentioned around 2000 rpms...
EDIT: Nevermind, I found it in this thread. Man I'm easy to confuse today. That was for an MT but you are right, even for that 4000 would make a wicked burn spot. |
05-31-2008, 06:51 PM | #7 | |
59
Rep 765
That was me who said that! :biggrin: I should have added in there that I did that in an auto transmission. For me I found that was a sweet spot and any higher RPM the back wheels would start to spin or I would get too much wheel spin off the line. 4000 RPM launch for the auto would be great for a smoke show! Maybe on the manual you might pull it off if you let off slowly. Not sure haven't driven this car with a MT. |
05-31-2008, 09:23 PM | #9 |
Tech. Certified
11
Rep 309
This is also the way to burn out your clutch, throwout bearings, etc. quicker. Letting out the clutch slow enough to not peel out at that RPM tends to put a lot of wear and tear on your system...
05-31-2008, 09:26 PM | #10 |
414
Rep 6,968
- There's nothing in my pocket other than knives and lint
05-31-2008, 09:52 PM | #11 | |
Tech. Certified
11
Rep 309
I want a ramp cake... |
