05-17-2008, 05:38 PM | #1 |
49
Rep 799
BMW Performance Front Rotors DIY
This is very simple installation and should only take 40 minutes or so to install.
All you will need is: Jack (optional rubber protector) 10MM Allen socket 6MM Allen socket 17MM Socket Torque wrench Bucket 1. Before Pic. Break free your lug nuts with 17MM socket. Do not loosen too much. 2. Jack up the car. I have the sport springs so I needed to find a nice spot in my driveway for enough room. A quick tip to save your jack points looking nice is to either buy a rubber spacer for your jack, or like me just cut the sole off an old shoe...works great! Remove the wheel. 3. Notice the bolts have white paint marks showing the line up points. If they are not marked well enough, mark them better with a Sharpie. Use your 10MM Allen Socket to remove these two bolts. 4. Use a bucket or something to rest the caliper on, do not let it just hang!!! 5. Remove the bolt holding the rotor on with a 6MM Allen socket. (I missed a pic of this during the install, but this pic shows the bolt) Remove the rotor and put the new one on. Tight the 6MM bolt. No need to torque it down a bunch, just make sure it is tight. 7. Put the caliper on and tighten the two 10MM Bolts back and forth until the white marks line up. It is a lot of torque to get them there, but I am not sure the exact amount. 8. Put back on the wheel and snug tighten all lugs in a star pattern. Lower the car and torque the lugs to 88 pounds. Your done, do the other side and have a beer.
05-17-2008, 06:03 PM | #2 |
Rep 93
Hottt, this is def something i'm looking to do and now that i know its that easy i'm game for sure. thanks! great write up
- 135is - Sedona Red Aluminum Trim Black Boston Leather Cold Weather Pkg Sports Pkg Premium Stereo PCD June 3rd! "The steering, the feel, the way you can adjust your line through the bend with the throttle. There is no other car made today in this sector of the market that gets even close. If you love driving, this is up there in a class of One." - Jeremy Clarkson - |
05-17-2008, 06:28 PM | #3 |
409
Rep 3,479
Drives: 19 M2C 6MT
how much and where u get them?
05-17-2008, 06:29 PM | #4 |
BMW ONE
15
Rep 630
Drives: 93 RX-7 R1, 135i
Did you feel the weight difference when you were holding them?
Dan from united BMW is selling them for $110 each...and they are covered under bmw maintenance!!
135i - Alpine White - Black Leatherette - 6-Speed - Sport Package - Aluminum trim - 6FL
05-18-2008, 02:29 AM | #8 |
49
Rep 799
Here are some answers.
I paid $105 each from Dan at United, I have only put on 4 miles since installing them, so they feel the same so far. There is not a seperate right and left rotor, so the slots run different on each side...which is perfectly OK. I was going to weight them but forgot, maybe the next guy can...but yes them did seem lighter during the install. My last track day the stock ones temp at 305 degrees after a 20 minute session, I will temp these at my next event June 5th and post the results to see if they run any cooler and or feel different at the track.
05-18-2008, 03:18 AM | #9 |
NRA Life Member, BMW CCA 30 year member
181
Rep 2,614
Saves a couple pounds of weight, plus, they look kool.
Resigned 1ADDICTS Moderator
“To disarm the people is the best and most effective way to enslave them.” – George Mason |
05-18-2008, 01:31 PM | #11 |
4449
Rep 7,594
Drives: '19 M2C
My fronts show up this Tues via Fed-Ex :biggrin:
www.ReTuneTheDeTune.com
2019 M2 Competition (Sunset Orange) |
05-19-2008, 08:18 AM | #12 |
4449
Rep 7,594
Drives: '19 M2C
That would be great info to have. Great DIY!
05-19-2008, 07:35 PM | #14 |
4449
Rep 7,594
Drives: '19 M2C
I weighed them on a UPS approved Toledo scale:
21.42 lbs each (Performance Rotor)
05-22-2008, 03:05 PM | #15 |
25
Rep 162
Drives: G87 & E88
How about some updated pics? I'd love to see how the rotors look with a few miles on them.
Thx!
06-19-2008, 08:02 AM | #17 | |
Rep 99
Do you have the weight of the stock rotor that you removed?
06-19-2008, 09:02 PM | #18 |
4449
Rep 7,594
Drives: '19 M2C
Unfortunately, I didn't weight the OEM rotor. I will take it to work on Fri and weight it.
*I thought some on the 1addicts did weight the oem rotor, but I can't seem to find it.
06-20-2008, 12:58 PM | #20 |
Rep 209
great!
You have less friction surface now.....How does that feel? You'll be amazed on how those things eat through your brake pads.....but if you have deep pockets.....not a concern at all....eh. |
06-20-2008, 01:53 PM | #21 | |
49
Rep 799
Nobody really makes pads yet. When they do I will most likely run something else when the stocks are gone.
06-20-2008, 02:27 PM | #22 |
4449
Rep 7,594
Drives: '19 M2C
Let's keep this civil
