      05-15-2008, 07:19 PM   #1
jwjusaf
Drives:
13.803@100.01 @ Bandimere (6200' ASL)
I ran last night at Bandimere speedway. The track was slick because it was sprinking off and on most of the night and the track was cold. The track is at 6,200 ft above sea level.
My car is 100% stock (~1680 miles) and had just over 3/4 tank of pump (91 octane) gas. I have a steptronic 135i w/ sports and premium.
My fastest timeslip reads:
R/T: .374
60': 2.105
330: 5.827
1/8: 8.918
MPH: 78.61
1000: 11.561
1/4: 13.803
MPH: 100.01
My fastest MPH run of the night was my slowest 1/4 time. All of my runs were 13.8X except 1 where I had TC on (oops), one where I spun out the entire 1st gear and some of 2nd and another that I just simply ran a 13.9 that run.
My slowest run (fastest trap speed thanks to massive wheelspin) reads:
R/T: .426
60' 2.368
330 6.197
1/8 9.307
MPH 80.98
1000 11.972
1/4 14.216
MPH 102.68
For all you timeslip nerds like me that like to graph and analyze this stuff... enjoy.
I ran 11 times.
Averaging all of my timeslips after removing the fastest and the slowest runs (to remove "flukes") I got:
13.910
Once the weather gets better out here and I can run on a dry and warm track I'd like to see how much these numbers change.
      05-15-2008, 07:32 PM   #2
sndprssr
Tech. Certified
11
Drives: '08 135i
That's not bad for that high up and a wet track. I can't wait to run it down here at 23 ft. above...
      05-15-2008, 08:40 PM   #3
Bizall
Bizall's Avatar
123
Drives: 2019 Honda Accord Touring 2.0
Very impressive. With the correction factor for the altitude...that is around a 12.9-13.0. Very, very nice.
2018 BMW M3 - 12.1 @ 121mph
2014 BMW 335i M-Sport (Sold) 12.4 @ 113mph
2008 BMW 135i (Sold) 12.8 @ 106mph
      05-15-2008, 09:54 PM   #4
0002s
Mein Führer! I can walk!
0002s's Avatar
45
Drives: Not a BMW
Really nice for your altitude.
      05-15-2008, 10:27 PM   #5
ModlessG
Drives:
That is a very fast time at Bandimere. Even with the cool weather ( which helps a lot) Your corrected time would be in the high 12s. You will be surprised how much slower the times are with warmer temperatures .
      05-16-2008, 07:47 AM   #6
jwjusaf
Drives:
I doubt 12's stock. I don't lose that much from altitude like a naturally aspirated would. Most people at Bandi that are boosted like us notice about 1/2 second change going to lower altitude which would put me in the 13.3 range. I think I'm right on par w/ other stock 135's to be honest.
      05-16-2008, 08:04 AM   #7
ModlessG
Drives:
You are right about the Boosted motor doing better at altitude. I ran my Mustang Gt up there my best was 14.68 @94 mph. that corrected to 13.0 @ 104 mph @ sea level. Still High 13s with poor traction is very good.
      05-16-2008, 06:14 PM   #8
MINI135i
139
Drives: 2019 M2C and 2013 FR-S
Turbos are pretty effecient at altitude.
Wait till you put it on a dyno and SAE correct it...your numbers will be sky high. Turbos here in Denver tend to fall somewhere between uncorrected and SAE corrected on a dyno.:smile:
      05-18-2008, 01:54 AM   #9
Bizall
Bizall's Avatar
123
Did you need a helmet to run 13.99 and under???
      05-18-2008, 07:32 AM   #10
jwjusaf
Drives:
ANOTHER PERSON FROM HERE IN DENVER W/ A 1!?
I haven't seen any of us around out in public yet. When I got my car on April 2nd I was told that there were probably only 4 of us around and I might be the only Black w/ red interior one. I hope to see you around!! (Maybe I WILL dyno it just for fun.
BIZALL: Yes... 13.99 and below you need a helmet, 14.00 apparently is safe enough to run w/o one :iono:
      05-18-2008, 07:35 AM   #11
jwjusaf
Drives:
I'm going back this Wednesday (May 21st). If any of you guys decide to show, make sure to say hi to the guy in the Black Sapphire Metallic 135i !
      05-18-2008, 10:57 PM   #12
MINI135i
139
I am still waiting on mine....probably July.
My stock 07 Cooper S (turbo) dynos at 200 wheel hp and 238 ft/lbs SAE corrected just for reference. At sealevel they come in at 165-170 whp/195-200 ftlbs. range.
I will dyno my 135i when I get it...I always like to have a stock baseline.
      05-18-2008, 11:42 PM   #13
Bizall
Bizall's Avatar
123
Won't have my baby then, but within a week or so I will. I'm planning a trip to PMP on June 6th though...the more, the merrier.
      05-19-2008, 04:24 AM   #14
jwjusaf
Drives:
My friend w/ his modded little M3 is going up there with me. over time I think it would be cool if several of us could arrange a meetup at a track to represent the 1's!
Unfortunately, I may not be able to make a meetup past June since I plan on moving to Virginia.
      05-19-2008, 05:25 AM   #15
Bizall
Bizall's Avatar
123
I wouldn't mind trying to head up that way before you leave. How much is it at Bandimere anyway?
      05-22-2008, 08:50 AM   #16
jwjusaf
Drives:
More 13.8's :-(
I can't launch it... it was 80 degrees last night which didn't help... but the track was nice and hot.
I was getting a ton of traction and just couldn't stick the launch. I only ran 4 times last night.
I think 13.8's is all I can get out of it. I know I am the limiting factor because 13.803 is just too close to a 13.7. I know if I didn't suck as bad it'd be better.
      05-22-2008, 10:55 AM   #17
Bizall
Bizall's Avatar
123
At least you're consistent. Have you tried dropping the pressure in the rears at all?
      05-22-2008, 11:29 AM   #18
Brandon26pdx
28
Drives: 2011 135i
Not bad at all considering the conditions and altitude (and transmission):biggrin:
      05-22-2008, 04:21 PM   #19
ramair311
60
Drives: M235i
More 13.8's :-(
Hey - we got our cars on the same day! I got mine at Murray here in Denver - after having my deposit down for 6 months. Jet Black with black/aluminum interior. Since then I've added;
JB2H
BMC panel filter
H&R Sport springs
CDV delete
When is the next test and tune date there? I'd like to see what times these mods will produce.
      05-22-2008, 11:28 PM   #20
jwjusaf
Drives:
JB2H
BMC panel filter
H&R Sport springs
CDV delete
Next test and tune will be next Wednesday the 28. You'll want to be at Bandimere at least by 4PM (Lines start a little early) I got there at 3:45 this last Wednesday and it was just about the perfect time. It gave me time to fill out the paperwork early then go straight in to get inspected. Bring a helmet with you because if they want to be asses, the first time you run that 13.99 or better they will send you over to the rental station to rent one. Also, eat before you show up. They charge stupid prices for crappy food. I paid just over $11 for a cheeseburger, fries, and a med drink.
Be prepared to draw a crowd too... our cars get attention out there (i.e. Wash it :-) )
      05-22-2008, 11:29 PM   #21
jwjusaf
Drives:
Nope... I purposely kept everything the same as I drive every day.
      05-23-2008, 07:14 PM   #22
ramair311
60
Drives: M235i
Thanks for the info! I won't be able to get over there next Wed - but I plan to ASAP.
Search this Thread:
Advanced Search
1addicts
