      05-06-2008, 08:51 PM   #1
TMc135
TMc135's Avatar
18
Drives: 2011 E90 M3
Tire/Wheel reco for Auto-x?
Just getting into the sport and would like to find a set-up that I can use in the summer for auto-x and then switch over to winter tires later in the year. This would help me limit my wheel set to two with a total of 3 sets of tires. Wasn't sure if should post here or wheels section. Thanks in advance for any advice/reco.
DD & Track Car: 2011 E90 M3 w/Ohlin R&T's, Vorshlag camber plates, Hotchkis swaybars and other mods.
(2008 135i modded - SOLD, 2006 E90 330xi - SOLD, 1995 M3 track car - SOLD)
      05-06-2008, 10:54 PM   #2
mikeo
Santa Fe Concorso
mikeo's Avatar
103
Drives: '11 M-sport 328i, '13 X1 28i
First, using wheels wide enough to mount appropriate sized auto-x tires will be a poor match for use with winter tires. I assume you are planning to run a street tire class (r-compound tires are not recommended for novice auto-crossers). Why not just use your OE setup for auto-x and buy an inexpensive 17" wheel/snow tire setup for winter? I've driven 4 events on my OE wheel/tire setup and they do OK if inflated properly to prevent rollover (leading the Street Tire class in season points). Yes, the OE wheels are not the lightest, but the runflats can be replaced when they wear out with less expensive tires with more grip. As a novice you will have much more to worry about than wheels/tires for the first season or two.
Santa Fe Concorso - The Southwest's Premier Automotive Gathering.
Search this Thread:
Advanced Search
1addicts
