04-29-2008, 06:46 PM | #1 |
27
Rep 932
SI B 12 10 08: N54 – Aftermarket "Engine Performance Tuning" Kits
SI B 12 10 08
Engine Electrical Systems April 2008 Technical Service SUBJECT N54 – Aftermarket "Engine Performance Tuning" Kits MODEL E60, E61 with N54 engine E90, E92, E93 with N54 engine E82, E88 with N54 engine E71 with N54 engine SITUATION Various aftermarket "N54 – Engine Performance Tuning" kits are being aggressively advertised to BMW owners. Depending on the manufacturer, these modifications may consist of a "turbo-tuner control module" (piggyback box) plugged directly into the TMAP sensor / DME connector, waste-gates vacuum plumbing alterations, or the DME "performance" software programming. In general, each aftermarket tuner claims a significant increase in engine power and torque of up to 40% over the stock N54 engine specifications (which are, respectively, 300 hp and 400 Nm). These alleged performance gains are achieved by an increase of the turbochargers boost in a wide range of engine speeds, in some cases exceeding the maximum designed turbo pressure of 8.8 psi by 50%. INFORMATION None of the aftermarket "N54 Engine Performance Tuning" kits has been evaluated, tested, approved or endorsed by the BMW Development or Service Departments. Any alterations to the originally designed and installed turbochargers control system or to the DME software may increase a vehicle's emission levels and may compromise its OBD II compliance. Moreover, to the best of BMW NA knowledge, none of the aftermarket "N54 Performance" kits have been certified (homologated) by the appropriate federal and state authorities (EPA/CARB) to meet street-legal emission requirements. BMW vehicles equipped with such "performance enhancement devices" without these certifications are not in compliance with EPA/CARB emission anti-tampering laws. Excessive turbocharger boost increases engine temperatures resulting in pressures and forces which may damage engine internal components and or may cause premature turbochargers failure. Due to increased engine output and the altered emissions characteristics, severe damage may be inflicted on emission control components, such as oxygen sensors and catalytic converters. Excessive engine loads, above the designed levels, may also compromise long term reliability and longevity of other drivetrain components, such as: clutch transmission, transfer case, differentials, etc. WARRANTY INFORMATION Modification of the vehicle or installation of any non-approved performance accessories or components attached to the vehicle which alters the original engineering and/or operating specifications or which results in damage to the other original components voids the warranty coverage on the affected original Drivetrain and Emission Control components. In general terms, the BMW warranty on Drivetrain and Emission Control components is void due to a modification where the modification, alteration or installation of a non-approved aftermarket part was responsible for the failure. Please make sure to inform BMW customers considering purchase of an aftermarket "N54 Engine Performance" kit of the above legal and technical implications. |
04-29-2008, 07:47 PM | #2 |
828
Rep 4,190
Tell me something I don't already know.
As the other forum has eluted to, it sounds like their first concern is emissions related. It does make the Dinan option more tempting. |
04-29-2008, 08:23 PM | #3 | |
76
Rep 5,970
Honestly I'd guess their first concern is warranty cost, but emissions tampering has more "bite" for the consumer. All BMW can do is void your warranty. Altering the emissions controls could carry fines from the federal government.....but I'm not sure when they'd ever have reason to check unless you're in a state that's doing smog testing. I would imagine the same applies for Dinan. Anyone know if they've gone through the trouble of CARB certification? |
04-30-2008, 04:30 PM | #7 |
323
Rep 1,804
Do you think dealerships will be actively searching for piggyback systems?
-Nick
2018 BMW 440i - M Sport, Exec Glacier Silver Metallic/Coral Red Dakota Retired: '00 323i, '06 325Ci, '09 135i, '06 Z4M Roadster, '93 525i, '76 2002, '14 X1, '14 M235i, '16 X4, '16 435i |
04-30-2008, 07:58 PM | #9 |
377
Rep 5,730
Drives: BMW i3 rex
Garage List 2018 I01 i3s | CURRENT [0.00]
2018 G01 X3 | CURRENT [0.00] 2017 I01 i3 | SOLD [0.00] 2017 F48 X1 | SOLD ... [0.00] 2016 I01 i3 | SOLD [0.00] 2017 F22 M240 | SOLD [8.00] 2016 F25 X3 diesel ... [0.00] 2006 E60 550 | SOLD [6.00] 2011 E90 335 | SOLD [8.66] 2012 E82 135 | SOLD [5.50] 2011 E82 1M | SOLD [7.94] 2007 E85 Z4M| SOLD [4.50] 2003 E53 X5 4.6is S ... [9.00] 2008 E92 328 | SOLD [0.00] 2008 E82 135 | SOLD [0.00] 2008 E90 335 | SOLD [0.00] 2003 E46 M3 | SOLD [7.50] 2006 E90 330 | SOLD [10.00] 2003 E46 330ZHP | SOLD [0.00] |
from a technical standpoint what is "excessive boost increase"? 11psi excessive????
05-01-2008, 05:49 PM | #11 |
Rep 72
I would say this is good news compared to what they could be doing. If they were specifically saying installing this part will void your complete power-train warranty that would be much worse than this "if the aftermarket component affects the broken component"
05-02-2008, 11:43 AM | #13 | |
Rep 72
If I'm reading this all correctly? Feel free to set me straight if I'm not. |
05-03-2008, 03:15 PM | #14 |
Throbbing Member
43
Rep 1,433
Isn't BMW Performance going to have a software upgrade for the N54 engine?
2014 Tesla Model S 85kwh
Previous cars: 2011 335d / Deep Sea Blue / Saddle brown / sport / premium 2008 BMW 135i / 6MT 2002 Z06 Corvette |
05-03-2008, 03:27 PM | #15 | ||
2146
Rep 10,176
05-08-2008, 07:58 AM | #16 |
Rep 17
More then 400bhp for your 135i
09-27-2008, 07:47 PM | #18 |
Rep 366
They all worry mostly about emissions instead of performance. Its the tree huggers controlling the auto industry.
The only difference I see is that a bimmer tune cost way too much compared to a tune done on a Mitsubishi or Subaru. Or even on a GTO
US Army 11C 1983-1993 09 Sedona Red Metallic 135i 09 Ford F-150 Platinum |
