Studio RSR
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > AUDIO/VIDEO + BLUETOOTH + Electronics/Alarm/Software > Bluetooth phone book persistence question
      07-12-2005, 09:47 AM   #1
johnfkitchen
29
Drives: 323is & 330i
Question Bluetooth phone book persistence question
If I connect my Bluetooth phone to somebody else’s E90, and it transfers my phonebook to that car, will those phone numbers be available to the user of that car after I disconnect? Is the answer the same for both iDrive and non-iDrive?
1998 323is SP manual with all the goodies in ArktisSilber + 330i auto SP PP CW iDrive/Nav SatRadio Active Steering Arktis/Beige/Poplar
      07-12-2005, 01:50 PM   #2
amcar
Drives: 2006 330i
Only if your phone is in the car
The phone book will be active only on an active bluetooth connection with the phone. So if you disconnect and get out if the car, the PB will not have your entries. I tried with my spouse's cell phone and the PB entries shown are only those for the active connection. Real cool...
      07-12-2005, 01:54 PM   #3
E90Fleet
South Africa
1307
Drives: BMW
As far as I know the phone has to send the phonebook each time it connects to the car, when you leave the book dissapears on the car
      07-12-2005, 01:57 PM   #4
johnfkitchen
29
Thank you amcar and E90Fleet !
      07-12-2005, 02:12 PM   #5
George Chronis
Drives: 330i 2006
Not sure about iDrive, but on non-iDrive, if you disconnect the phone, you don't have access to the numbers as you don't have access to any of the commands in the phone menu. If you try to go there, it says connecting, and if the phone is not there, you don't get anything. If you connect a different phone, you get the numbers of the phone connected.
      07-12-2005, 02:15 PM   #6
George Chronis
Drives: 330i 2006
No, it doesn't send it every time. It send it the first time only, then it stores it and it updates every time you connect. If you don't connect, then it just doesn't show up at all. I know this because when it send data, my phone button response is veeeery sloooowwww and I can see the phone sending data over BT. This won't happen again, unless I delete the pairing and I pair again.
      07-12-2005, 09:41 PM   #7
YYdoodle
115
Drives: E92 M3 fanatic
Awesome I had the same question. Thanks for asking john and thanks for answering all.
      07-25-2005, 05:47 PM   #8
johnfkitchen
29
I have found that phone numbers/names stored by voice command are usable on both our two bluetooth phones. The phone does not have the number added to its phonebook, but it's stored in the car's phonebook. Hope this makes sense.
      03-11-2007, 11:32 AM   #9
nikegunit
nikegunit's Avatar
Jordan
Drives: 335i
Originally Posted by Jak View Post
please confirm as correct
i can see this is interesting to you, but you've made 5+ identical posts in various threads...why not just start a new one!? (sarcasm, dont start a new one with this topic)
Search this Thread:
Advanced Search
