05-04-2024, 12:28 PM | #1 |
Rep 6
Rattle noise from drive door
I hear a rattle noise from driver door in potholes, How to fix it?
I attached a video as well. When I put a folded paper in here, the sound stops. Last edited by alhsk; 05-04-2024 at 12:39 PM.. |
05-04-2024, 05:46 PM | #2 |
7504
Rep 6,870
Drives: '18 M550i|'21 X5|'03 540i
Garage List 2013 VW Tiguan [0.00]
2015 Infiniti QX60 [0.00] 2021 BMW X5 [0.00] 2003 BMW 540i [10.00] 2018 BMW M550 [10.00] |
Are you the original owner and/or have you pulled the door card? Definitely a clip or grommet either broken or missing.
2018 M550ix|Carbon Black|Dinan Modifications|2003 540i|Jet Black|M-Sport|2021 X5 Mineral White
Prior BMW's: 1987 325e|1993 740i|1998 740il|2001 530i|2002 745li|2007 750li|2006 750li|2001 530i|2012 535xi| |
430Scud275.00 |
05-04-2024, 06:35 PM | #3 |
275
Rep 316
Ditto to what Joe said. Door panels are typically held on with plastic pins...one is either missing, broken or crushed and no longer securing your door panel. I found the ones on my E39 BMW and keep several handy, as the door panels have to come off every few years to reseal the vapor barriers. I can inspect and replace any that get broken during the removal process.
05-05-2024, 04:26 AM | #4 |
Rep 6
05-05-2024, 07:34 AM | #5 | |
7504
Rep 6,870
Someone removed it, maybe the dealer to address something at some point internal to the door (speakers, etc) and most likely one of the many pins or fasteners broke putting it back on, which basically involves lining up the pins and clips and popping the panel with your fist to pop it back on. VERY is fix. You just need to pop it off and resecure it with a new pin or two. The area that is loose is where the culprit is.
05-05-2024, 11:29 AM | #7 | |
7504
Rep 6,870
Now full disclosure, I would probably pay the dealer to sort it out. Not because it’s hard, but because it’s probably cheap enough and they do this all the time. I pop the door cards off my E39 all the time, but I’d probably couple this with an oil change. Make sure you have a set of vinyl tools. I use them all the time for many things. Don’t use a metal pry tool or screwdriver.
05-05-2024, 09:28 PM | #8 |
Rep 42
The handle bar is the biggest pain, popping the clips off isn't so bad. You probably don't need to remove the whole door card, but will likely need to pop off the bottom too to inspect and slide in a new clip. For this car, the clips they use often break and are pretty much single use. If you are going to pop the door card off, buy 10 of these clips first and replace all the broken ones before you snap it back in. By broken, if they are don't look exactly the same as the new ones, replace them.
05-07-2024, 07:01 AM | #9 |
Rep 6
I've checked the clips, and they appear to be fine. It seems the noise is coming from the plastic. I applied Gummi-Pflege spray to the edge of the yellow circle, and that resolved the issue.
