The Tire Rack
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N54 Turbo Engine / Drivetrain / Exhaust Modifications - 335i > Air cold side diagram - 30ff intermittent code
      05-01-2024, 05:07 AM   #1
suspect
27
Drives: car
Does anyone have a line diagram for the engine cold side where the air box and charge pipe is? I have an intermittent 30ff code boost not meeting target. It happens randomly and the target would be 16.5 but it will only hit 13.5psi. Other times it gets 16.5-16.7psi.
I replaced the ofhg and disconnected three vacuum lines (#5,#6 and another going around the air box which I think goes to brake booster?) and the rear diverter valve. This has likely caused the issue and a diagram would help before I think of fixing a pinched intake manifold gasket.
On realoem I could only find the hot side vacuum lines.
      05-05-2024, 09:10 AM   #2
suspect
27
Drives: car
Does anyone know what is the tube/pipe going into the front intake? What does it do? It’s held by a grey twist locking mechanism.
      05-05-2024, 05:25 PM   #3
dmckmc
50
Drives: BMW 535i E60 (2008)
sounds like you are describing the bypass valve (blow off valve) hose. it routes bypassed air back to the intake (instead of vented to atmosphere).
TiAgAu156.00
      05-06-2024, 03:04 PM   #4
suspect
27
Drives: car
I think I left this unlocked. After turning it to the opposite position, the car has stopped throwing a 30ff shadow code. Don’t know why it works if all it does is route bypassed air back to intake.
