04-30-2024, 01:24 AM | #1 |
32
Rep 98
Is it just me or is the wheel gap freakishly bad? I was looking at just lowering springs, but I’m seeing that using them with stock components is asking for trouble.
What’s the recommended setup? I have adaptive suspension, maybe that’s why it’s so high? |
04-30-2024, 01:30 AM | #2 |
3131
Rep 4,380
tires appear to not be an incorrect aspect ratio. what size are your tires?
you may do a mild lowering, such as eibach pro-kit springs and F80 bumpstops. this will minimally affect the damper lifespan. |
04-30-2024, 01:32 AM | #3 |
32
Rep 98
18x8.5 et38 245/40/18 square, should be right according to apex
04-30-2024, 01:41 AM | #4 |
3131
Rep 4,380
the tire size is correct. i guess the gap is giving the illusion the tire is a lot smaller. the right side gap looks ridiculous. not sure the eibach pro-kit will reduce the gap enough, but it will help some
04-30-2024, 01:44 AM | #5 | |
32
Rep 98
Should I be considering a full coil over setup? |
04-30-2024, 02:04 AM | #6 | |
3131
Rep 4,380
as with any brand comparison, the pros and cons between different brands of springs, dampers and coilovers is very subjective. if you get a non-adaptive coilover you will need to code out edc or get an edc delete kit. if you opt for an adaptive coilover KW DDC is what i'd suggest. |
SharpDrives31.50 |
04-30-2024, 06:28 AM | #7 | |
32
Rep 98
04-30-2024, 07:39 AM | #8 |
3131
Rep 4,380
SharpDrives31.50 co_440i120.00 |
04-30-2024, 07:52 AM | #9 |
32
Rep 98
alohasurftoad3130.50 co_440i120.00 |
04-30-2024, 11:21 AM | #10 |
5946
Rep 10,317
04-30-2024, 11:31 AM | #11 |
3131
Rep 4,380
assuming your dampers are still good these are the Eibach Pro-Kit springs part numbers:
E10-20-031-02-22 if RWD E10-20-031-05-22 if X-Drive because suspension labor is a big part of the cost, you should also replace the strut mounts, spring seats, shock protectors and bump stops as these items are usually worn and torn as well. |
04-30-2024, 12:15 PM | #12 |
158
Rep 132
Drives: 2018 BMW 330iX Sedan
Mine was stupid high too, I hated it. Seems to affect LCI cars more than pre-LCI. Your choice of 245/40 makes the gap look worse, as they are slightly shorter than 225/45.
Pics before and after-lowering. I'm on KW Comforts |
04-30-2024, 12:54 PM | #13 |
120
Rep 119
I'm about to run into this same situation with new Aodhan AH11s and the same wheel and tire size.
If it's correct that we can run Eibach pro with stock non-EDC struts, that may be a route I go! |
alohasurftoad3130.50 |
04-30-2024, 01:00 PM | #14 | ||
32
Rep 98
Killer color btw! |
jmanB45157.50 |
04-30-2024, 07:24 PM | #16 |
158
Rep 132
04-30-2024, 07:46 PM | #17 |
376
Rep 1,433
That wheel gap! I'm laughing with you, and hope you find a solution soon.
2017 X5M - Current
2017 F31 Wagon - Current 2014 M5 ZCP - Retired 2011 135i Coupe - Retired 2007 335i Sedan - Retired |
05-01-2024, 01:33 AM | #18 | |
32
Rep 98
But now I’m kind of at a loss |
05-01-2024, 06:00 AM | #20 | |
Idiotic lifter of heavy stones...
2006
Rep 2,191
Drives: 2015 F31 325D M Sport touring
You now need to lower it as you've suggested This is my RWD F31 on Bilstein B4S shocks with Eibach pro kit springs; running all new Sachs top mounts all round with OEM BMW dust boots/bump stops etc - no need for F80 ones unless you go much lower I have fitted all new suspension arms throughout as well; I did a FULL suspension overhaul As it stands on its summer 18" 405Ms with 235/45/18 tyres: Zero issues; zero rubbing even when fully loaded and handles superbly Would highly recommend
My car: 2015 F31 325D M Sport Touring in Glacier Metallic Silver - Keeping it OEM 'Plus'
Project: https://f30.bimmerpost.com/forums/sh....php?t=1982298 |
05-01-2024, 07:17 AM | #21 | |
32
Rep 98
Yeah I’ll definitely be exploring a complete overhaul. |
danb19792006.00 |
05-01-2024, 06:37 PM | #22 |
158
Rep 132
In case you haven't seen it, there's a thread on the Eibach 05 springs that aloha mentioned above. Here's a 340iX on those springs paired with Koni SA shocks:
https://f30.bimmerpost.com/forums/sh...7&postcount=27 |
