Extreme Powerhouse
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Suspension | Brakes | Chassis > N52 325i Differential
      04-27-2024, 01:18 PM   #1
danielkane82
Drives: e92 325i 2007 N52
Hi All, glad to join the community
My differential on my 325i must be laid to rest unfortunately. I'm looking to install a new differential, and I'm wondering is the OEM differential P/N 7519941 the only directly compatible differential I can purchase ? Or would a 330i differential be a straight swap ?
Based in Dublin, Ireland just for reference.
      04-28-2024, 07:19 PM   #2
cheerio
cheerio's Avatar
Australia
144
Drives: E61 + E36 + E90 scrapheap
330i diff flange attaches to the driveshaft via a guibo with 3 bolts (and has a lower ratio). 325i diff flange is 4-bolt. Not compatible. 323i diff is compatible if you got those in Ireland.
      05-03-2024, 10:11 AM   #3
gaze2
12
Drives: E91 325i 6MT 2005 EU-spec
You could try looking up part numbers on real.oem to be sure what will fit what.
And also you should take the opportunity to swap to differential from an automatic car if you want to increase torque by making your gears a bit shorter
