The Tire Rack
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > AUDIO/VIDEO + BLUETOOTH + Electronics/Alarm/Software > SOS Malfunction *Not Typical Symptoms*
      04-26-2024, 11:48 AM   #1
CK93E92
Drives: 2008 E92
Hello All,
This is my first post ever on a forum like this. I have recently purchased a 2008 E92. 126k miles. Non-turbo automatic RWD model.
I got the SOS call Malfunction randomly one day. I have been on the forums and have read just about everything.
I have replaced the battery, alternator recently.
I have ordered the bypass loop and tried to bypass the Sat Radio, MULF and TCU.
I HAVE sound through the radio, my CD player works and I have all chimes. However my Aux shows as an option but does not work. And I've lost all options for Bluetooth.
In addition to that I have a "heartbeat" pulse/static through all of the speakers.
When I looked at the fiber optic connections all had a red light that was pulsing and matched the static sound coming through the speakers.
I've check all the fuses, tried a replacement amp, tried the bypass. I've tried to just disconnect the battery.
Does anyone have any assistance? I know you can code it out but I have absolutely no idea how to do that.
      04-26-2024, 07:58 PM   #2
sam9116
16
Drives: ​
So your TCU no longer works, SOS call malfunction is related to TCU
Remove your TCU from the car
Install most by pass loop on TCU green cables
transfer and combine all wires inside the white plug from the TCU to the MULF blue plug, MULF will take over bluetooth call functionality. All pin locations from the TCU plug transfer directly to the same pin location on the MULF, you should not have to plug a pin into a hole where there is already a pin
You do have to tell the car you no longer have the TCU by coding it
remove
$612A BMW ASSIST
$619A EMERGENCY SOS CALL SYSTEM
from VO using NCSExpert
shoot me a message if you need help to setup coding, there is no skipping this
      04-27-2024, 11:20 AM   #3
ctuna
1926
Drives: 325xi 06 wagon MT
Remove SOS totally BMW doesn't support it since 2008.
Remove SOS totally BMW doesn't support it since 2008.(US car at least)
http://www.e90post.com/forums/showthread.php?t=1181654
To get the TCU you totally out of the loop you must remove or totally dissconnect
the TCU module and jimper the most loop plus program it out at leas the Kombi(instrument cluster)
or VO program it out.
      05-11-2024, 08:35 AM   #4
CK93E92
Drives: 2008 E92
ctuna & sam9116 I wanted to give an update to let you know I've fixed the problem. After further research on some older threads I learned that phones back when th car was new had been crashing the Bluetooth module in the car. I also paired my Samsung Galaxy Z Fold 3 to the car and it worked for a little while until one day the SOS light popped up and the "heartbeat" in the speakers.
To fix the problem I removed all of the fuses pertaining to the sound system and the telephone in the car. I also unpaired the BMW from my cell phone. I disconnected the battery for 30 minutes, inserted the fuses and then re connected the battery. My Bluetooth was now working, as well as the AUX. The Heartbeat went away and the SOS malfunction disappeared.
Thank you for your help!
