F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > General F30 Sedan / F32 Coupe / F36 Gran Coupe Forum > EDC Shocks to Standard Shocks?
GetBMWParts
      04-21-2024, 10:07 AM   #1
David Kunitz
Mr OEM
David Kunitz's Avatar
South Africa
739
Drives: 2012 BMW 335i
Good day,
My 2012 F30 335i has the Adaptive M Suspension, which don't get me wrong is a great optional extra, however it has been 385, 000km (240,000mls) and they are 100% toast.
I would like to install standard F30 shocks as they are much cheaper, lighter and there is less to go wrong with them.
Will the standard shocks fit correctly?
And how do I code out the EDC from the car's computer?
      04-21-2024, 10:41 AM   #2
Fredo
203
Drives: 2012 335i
Hello. Please review my thread. I replaced EDC with non-EDC.
https://f30.bimmerpost.com/forums/sh....php?t=1657753
The code was done remotely.
      04-21-2024, 10:56 AM   #3
David Kunitz
Mr OEM
South Africa
739
Many many thanks for this!
I have searched the forums but haven't been able to find anything about this for some reason
So if I buy OEM shocks do you think I will need to replace the springs as well or could I leave them alone?
And before you coded the car, what warning lights did you have?
      04-21-2024, 01:23 PM   #4
Fredo
203
Drives: 2012 335i
I believe you can leave the springs alone.
My shop did all the work for me, so I didn't have chance to see the warning lights.
      04-21-2024, 01:36 PM   #5
David Kunitz
Mr OEM
South Africa
739
Very well then!
I thoroughly appreciate your advice, many many thanks!
      04-22-2024, 09:25 AM   #6
F30_Drew
F30_Drew's Avatar
Drives: '13 F30 335i 6MT MSport RWD
You could go the route of remote tuning, or you could code out the errors with a hardwire kit that you mount in or near the wheel well. This kit basically tricks the car into thinking that the EDC system is still working. (https://www.ecstuning.com/b-kw-suspe...t/68510301~kw/)
My car is still under warranty from some large repairs that BMW did. So for me, tuning is out of the question because I'm unable to tamper with my ECU. I've heard good things about both so it doesn't seem like you could make the wrong choice here. If you do not want to find a way to fasten these EDC kits, then just go with tuning.
Let me know how it goes!
      04-22-2024, 09:35 AM   #7
David Kunitz
Mr OEM
South Africa
739
Originally Posted by F30_Drew View Post
You could go the route of remote tuning, or you could code out the errors with a hardwire kit that you mount in or near the wheel well. This kit basically tricks the car into thinking that the EDC system is still working. (http://tiny.cc/spbtxz)
Thank you so much for letting me know about a second option!
I am hoping that remote tuning works out to start with, just waiting for my mechanic to get back to me about it!
Hopefully I can get it done soon, will let you know how it goes
      04-23-2024, 08:25 AM   #8
Fredo
203
Drives: 2012 335i
I had some issues after the EDC removal. What that coding did was to update the Vehicle Order (VO) to pretend the car came out of the factory without the EDC option.
A couple of years ago, I needed to replace a part (Fuel Control Pump Unit P/N 16147411596) which required to be coded into the car. My mechanic had a lot of trouble to make this work.
His notes say "Unable to code EKPM3 with standard BMW ISTA+. Found vehicle order has been modified which caused the ISTA+ programming issues. The EKPM3 is now coded successfully (the only way to code this vehicle is E-SYS only)."
He also said any new part that requires coding will have similar issues.
      04-23-2024, 11:09 AM   #9
David Kunitz
Mr OEM
South Africa
739
Oh dear, that seems to be quite an issue!
I will have to look into this further, appreciate you letting me know!
      05-09-2024, 09:37 AM   #10
David Kunitz
Mr OEM
South Africa
739
*Update*
Finally got the shocks replaced today with OEM passive shocks.
Now, would I recommend you go from Adaptive to *OEM* Passive shocks, definitely not.
The reasone being is that the front shocks actually don't fit properly with the swaybar link.
Only my left shock was able to fit but the right one has a different bracket that doesn't line up correctly.
So what did I do, well the smart guy who helped me with the install built a new bracket so that it would all fit correctly, you definitely need a professional to do this as these are important saftey components.
I have just driven the car back home and it feels absolutely brilliant, if you want to do this conversion, rather get good quality OE+ components as they will fit perfectly!
Apart from that I only have one warning on the i-drive for the chassis, *Not the chassie stabilisation warning lights, don't worry*
Also, the car keeps itself in comfort, I might decode the shocks at some point, but I do not want any further issue's as mentioned previously, I will just see if I can live without Sport+ and make a decision from there.
      05-09-2024, 09:49 AM   #11
eff32fl
eff32fl's Avatar
1088
Drives: 2019 440i M Sport THP MPPSK
Originally Posted by David Kunitz View Post
*Update*
No sport or sport+ I'm not sure how you manage!
      05-09-2024, 09:54 AM   #12
David Kunitz
Mr OEM
South Africa
739
It will be tough, I've only driving it for like 15 minutes so far, just so glad that it feels like a car again, almost 400k on original shocks is far too much!
      05-09-2024, 10:03 AM   #13
eff32fl
eff32fl's Avatar
1088
Wow that's a lot of KM. You definitely got your money out of them.
      05-09-2024, 12:47 PM   #14
freakystyly
3085
Drives: F22 B58 6MT
You could have used two left end links.
I believe coding can be done remotely if needed, you would need a laptop and appropriate cable or wifi dongle and some digging around in your trunk to disconnect the module.
      05-09-2024, 01:36 PM   #15
David Kunitz
Mr OEM
South Africa
739
Yes, very good idea, unfortunately we tried that and it still didn't fit.
BMW definitely didn't want people to change these shocks it seems.
I have been reading forums on how to code it out, I might have also found a local guy who can help me with the process as well.
Will update this thread again if I get it done.
      05-09-2024, 01:46 PM   #16
freakystyly
3085
Drives: F22 B58 6MT
Ok, good you got it to fit at least.
I went with aftermarket so I can't speak of that exact situation.
      05-09-2024, 01:51 PM   #17
David Kunitz
Mr OEM
South Africa
739
Yes, that is definitely the better route, just glad I got mine right again
f30post
