BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Suspension | Brakes | Chassis > E92 335is - front strut leaking. Recommendations for replacement?
      04-19-2024, 12:53 PM   #1
AAAAAAAAAA
Drives: '03 M3, '13 335is
My 2013 335is coupe's front left strut is leaking (I noticed it a while ago .. finally took it to indy shop for other work, and they flagged it too)
The shop recommends replacing both front struts/mounts/bump stops/guide tubes/hardware. They said they only really use OEM parts.
If you were me would you consider upgrading suspension setup to something else? Different brand/setup? Coilovers?
And if I were to upgrade, I'd need to do the rears too correct?
Lastly the shop quoted $2400 parts+labor for OEM replacement. Is that reasonable? I am in HCOL area (Boston)
Thanks in advance
      04-19-2024, 06:08 PM   #2
335i54n
319
Drives: e90 335i, e39 m5
yes, yes, yes, no (unless dealer direct factory parts)
imo b14 - little lower than msport, bc rm-msport or higher or just b8 all around
      04-22-2024, 05:20 PM   #3
pbinpb57
Drives: 2003 E39, 2008 E90, 2011 E92
2011 328i E92  [0.00]
2008 328i Sedan  [0.00]
2003 525i  [0.00]
$2400 is obscene, but that's dealer pricing. I recently installed Koni Special Active, front and rear, on my wife's E92 Coupe. She is a very happy camper.
      05-03-2024, 09:53 AM   #4
zero2sixtyZ
954
Drives: e92 + f15
Depends what you're looking for in terms of ride and handling.
I'd skip the shop that you went to, and I have an idea of which one it might be. Can make recommendations for a better local shop if you want to go aftermarket / bring your own parts route.
I would consider options from FCPEuro, have them shipped to you, and get a quote for install + alignment.
For $2400, you could get into a nice coilover setup, (factor in some include camber plates to replace mounts, etc) but again it depends on the end goal.
Tags
335is, coilovers, e92, shocks, struts, suspension
