2Addicts
2Addicts
2Addicts | BMW 2-Series forum Technical Topics Suspension | Chassis | Brakes F8x Rotors with stock M235i wheels?
      03-29-2024, 08:18 PM   #1
tbuck
tbuck's Avatar
1193
Drives: 2011 E92 M3, 2016 F23 M235i
Ok, so I have done quite a bit of searching on this and I have seen some contradictory information and just wanted to do a check here hoping someone that has done this before will comment.
I have recently purchased an M235i for my daily duties and have a plan to do a few mods over the next couple of months. I know you can put the F8x 380mm rotors on these cars with the blue calipers by using the SLG adapters or other similar ones. I have read that you can use them with 18" wheels and that they will "work" with the OE wheels but will require spacers to fit. I have read mention of several different sizes that are "required", so no clear answer to that. My desire is to get the mostly worn-out brakes upgraded (not cheap by itself obviously) and then at a later time get some other/larger wheels, but I can not do both at once. I would like to buy some time by getting a set of spacers required to make it work for now.
So, my question is, are we sure the OE M235i style 436 wheels will clear the F8x brake rotor/caliper setup and, if so, what size spacer is required to make that happen?
Thank you all for your help!
      03-29-2024, 10:04 PM   #2
jb-slow
111
Drives: m235i
Fits just fine with a 10mm spacer, excuse the dirt.
      03-29-2024, 11:45 PM   #3
tbuck
tbuck's Avatar
1193
Great, thanks! I have seen people say 5mm, 10mm, 12mm so just wanted to be sure. Thanks again!
      04-29-2024, 08:00 AM   #4
Jaik
Drives: White
I am having issues with SLG adapters at the moment - they space the front calipers out 23mm instead of 20mm... which for me is enough for caliper to wheel contact on 719M wheels. I am also having issues with the rear adaptors and the rotor not centering in the caliper.
https://f30.bimmerpost.com/forums/sh....php?t=2049292
      04-29-2024, 10:48 PM   #5
jb-slow
111
Drives: m235i
I have the adapters from kern, they fit perfectly. I do have to cut the ears off the pads to clear the wheels though.
      04-30-2024, 06:23 AM   #6
tbuck
tbuck's Avatar
1193
I had the very same problem with the SLG adapters. It placed the pad off the surface of the rotor at the outer edge and a nice 6-7mm gap on the inner. This also had the caliper make contact with the stock wheels. In the end I was unable to use the kit at all. Very disappointed to say the least.
      04-30-2024, 09:16 AM   #7
Jaik
Drives: White
tbuck did you return the kit?
      05-01-2024, 06:13 AM   #8
tbuck
tbuck's Avatar
1193
I have not, too late now. I had it for a bit before I tried it.
2addicts
