03-10-2024, 02:03 PM | #1 |
Rep 1
Amplifier Replacement Suggestion F30
Hi Guys!!!
My Amp, passed away ! i need asap a replacement ! Please help me with your suggestions a part of buying a original Harman Kardon 12 channels This is the part number 65129390140 Cheaper one accepted too ! |
03-10-2024, 03:09 PM | #2 |
4531
Rep 5,396
Drives: 2015 BMW 335i x-Drive Auto
Best amplifier replacement upgrades below. All include an upgrade to a new modern DSP system that is light years ahead of the 12 year old DSP in the BMW Harman Kardon system.
BMW BASE AUDIO For BMW Base Audio System (not sold in US), the Audiotec Fischer Match 7DSP amplifier, plus 1-2 Match cable harnesses to run from trunk amp location to head end in the dash. This makes it plug-n-play. BMW HIFI AUDIO For BMW HiFi Audio System (lowest level sold in US), the Audiotec Fischer Match 7BMW amplifier. This is a totally plug-n-play system that replaces the stock factory amplifier. BMW TOP HIFI/ HARMAN KARDON For BMW Top HiFi/Harman Kardon Audio System, the Audiotec Fischer Match 10DSP amplifier. Plus a Mobridge DA-G2 is needed to handle the conversion from the HK fiber optic headend to the 10DSP. This replaces the stock HK factory amplifier. UNDERSEAT SUBWOOFER UPGRADE All three of these Match amplifiers are like two amplifiers in one chassis. The have a separate higher power amplifier for the two underseat subwoofers. Upgrade the underseat subwoofers to Earthquake SWS-8Xi (2-ohm). Earthquake spacers at about $27 per pair are needed for the installation into the BMW underseat speaker cabinets. Hope this helps someone! |
03-10-2024, 03:47 PM | #3 |
Rep 19
I’m going to throw the Mobridge K2 8.1.1 amp in here as well. Takes up less space than the original and sounds great. Tons of tuning options and it can handle a dedicated sub in the rear. Also plug and play with the Technic harness and requires no re-coding for MOST applications replacing a stock HK amp while keeping all factory chimes/front & rear PCD, etc.
03-10-2024, 11:28 PM | #4 | |
542
Rep 508
Have this combo running two pairs of Focal es100ks, Morel underseat and old but well preforming Boston Acoustics sub. Run active on the front es100ks. Nice soundstage that sits above the dash and has great extension left and right. Bass is tight and articulate and sub bass can reach from 15hz -60hz and is way beyond the capabilities of any drop in underseat woofer solution. Gets my vote 😀 Last edited by NealfromNZ; 03-12-2024 at 05:05 AM.. |
