2010 2011 BMW 5 Series Forum F10 CiC head unit constant turning on/off |
03-03-2024, 04:57 PM | #1 |
Rep 14
My 528ix 2012 CiC head unit keeps turning on and off. After turning it on and off a few times, it finally stays active and lasts for a while. Did you have the same problems? Does anyone have experience?
03-23-2024, 05:31 AM | #2 |
Rep 1
I've had this recently on a 2016 F10, I think this is an NBT unit?
Anyway, I cleared all personal data through the iDrive menu (had to try around 20 times as the unit would restart each time I began the process) but it is now resolved. Settings > Instr. Cluster Display > Clear Personal Data Possibly worth a try. |
Steinway7.50 |
03-24-2024, 02:35 PM | #3 |
91
Rep 109
Maybe your hdd is dying. Buy another one hdd but it needs s.m.a.r.t. option. I saw related post of this issue here on 3 series forum, as i had F31 before my F10, and it's a bit of PITA to recover but it is manageable to do it.
Steinway7.50 |
03-24-2024, 04:37 PM | #4 |
Rep 14
[QUOTE=Carr0t84;31011164]I've had this recently on a 2016 F10, I think this is an NBT unit?
Anyway, I cleared all personal data through the iDrive menu (had to try around 20 times as the unit would restart each time I began the process) but it is now resolved. Settings > Instr. Cluster Display > Clear Personal Data Possibly worth a try. https://www.youtube.com/watch?v=FUAbWyXONv4 Thx 🤝 I'll try it but not sure that I have "Clear Personal Data" option on my CiC 2012 🤨 |
03-24-2024, 04:40 PM | #5 | |
Rep 14
Good thing in this case is that it is manageable for good bmw media tehnician |
zrile91.00 |
03-24-2024, 04:45 PM | #6 |
91
Rep 109
It is a bit of hdd cloning process and a bit of programming but nothing too scary to do if your hdd is still in dying process where you can still access all data. Just search in 3 series forum section "dying headunit hdd" and something related will come up! I hope i helped a bit... hdd is not expensive and maybe fewchours of pc work is needed, maybe less...
Steinway7.50 |
03-25-2024, 05:24 AM | #7 |
Rep 14
[QUOTE=zrile;31015098]It is a bit of hdd cloning process and a bit of programming but nothing too scary to do if your hdd is still in dying process where you can still access all data. Just search in 3 series forum section "dying headunit hdd" and something related will come up! I hope i helped a bit... hdd is not expensive and maybe fewchours of pc work is needed, maybe less...
Thx 🤝 |
zrile91.00 |
