Question Re: LED License Plate Bulbs
05-26-2006, 04:12 PM | #1 |
Larry from Los Angeles
14
Rep 296
I know that when you put an LED bulb in most BMW or MBZ cars, the computer thinks there is a burnt out bulb because the low power draw.
However, does anyone know if every bulb in the BMW will trigger a FAULT on the computer? I researched the License Plate bulbs (I love the white look of the new Lexus GS License Plate Bulbs): BMW uses a 6418 5 watt bulb. It's called a FESTOON type bulb. It looks like a narrow glass tube with metal at each end that fits in the socket. Looks like a bullet. SuperBright LED's, Inc. sells an LED version of this bulb (3910-W6). I'd buy them if the license plate bulb housing will NOT send a fault with the LED bulbs. By the way, for any electrical engineers out there: This LED bulb draws 32 mA's of current. I know NOTHING about amps, so I wonder if this would trigger a fault on the car computer. If we can figure this out, I'm sure there will be a lot of you who will want to change this bulb, especially since it is not expensive and access to change it is really easy. Thanks for all your help. Larry in Los Angeles P.S. I called the bulb company, but they're closed for the holiday. I'll call them on Tuesday. |
05-26-2006, 09:53 PM | #2 | |
569
Rep 7,519
Drives: 2009 E90 335i MT
How much of a current increase/decrease is needed to detect a failed bulb I don't know.
2009 E90 335i Montego Blue · Black Leather · Burl Walnut · 6MT · US Spec
SatNav • ZPP • ZCW • 6FL • TPMS • iDrive • PDC • HWS • Xenons • BMW Assist • Power Rear Sunshade • Logic 7 European Taillights • Rear Foglamp • OEM Alarm • PicoTray • DataToys XM-DVR • Multi-view Processor Quaife ATB LSD • Short Shift Knob • Hartge Anti-Roll Bars • AP Racing Front Brakes • 19" Style 269 |
05-27-2006, 12:09 AM | #3 |
73
Rep 1,754
I have ordered LED bulbs from Bimmian.com.
Yes, the fault code came out right away. If u really want a "Lexus" look licenese plate light, you can choose Xenon look light bulb, just like lots of ppl do on this forum. |
05-27-2006, 12:34 AM | #5 | |
341
Rep 16,407
05-27-2006, 12:41 AM | #6 |
14
Rep 296
Thanks for the detailed testing info.
After I wrote this thread, I discovered the regular xenon super white bulbs. I think I'll get those for fun. They cost $2 a piece. How can you go wrong at that price. And, by the way, it's not that I want a Lexus (I've had an SC400), I just like the superwhite look of the license plate lights. It goes GREAT with my titanium silver car color. Very cool. Thanks all. I've called my dealer and moved up my delivery date for my new 330 to June 6th. L |
05-27-2006, 12:51 AM | #7 | |
73
Rep 1,754
05-27-2006, 02:06 AM | #8 | |
IT'S MORPHIN TIME!!!
Rep 123
I got the same LED light for my licence plate and the fault code does come out. I'm not an electrician or anything, but I read somewhere saying to put a 30 Ohm, 5 Watt resistor (I don't know how they came up with this resistor... I'm guessing maybe since the stock bulb is 5 Watts? I don't know ). But I did it anyway, using splice taps (so no wires were cut), and the fault code went away. The only concern I have now is that the resistor gets really hot, just like the stock or xenon-like filament bulbs. Maybe this is now a good time for someone else to verify if the resistor I used is correct But this doesn't really bother me and I just make sure that the resistors are not touching anything. I actually have LEDs for all my interior lights and sidemarker as well, and the license lights are the only one that gave me the fault code. I originally bought the Bimmian Xenon-like Interior Bulb Kit (16 Bulbs that replaces all Interior Lights, including license plates). They're whiter than the stock bulbs, but I was disappointed with their brightness (dimmer than the stock IMO). So I tried white LEDs, and man, they're way better than the stock and much brighter than the Bimmian bulbs. The white LEDs in the licence plate really compliments my Alpine White Just keep in mind that if you're going this route, you'll either encounter fault codes or hot resistors I can post pics if anyone is interested (or if I find my camera ), but I can't compare the LEDs to the Bimmian since I've already sold the latter. I got the Bimmian for $60, but you can get them for about $40 I think. The LEDs however, can be bought for less than $2 each |
05-27-2006, 10:38 AM | #9 |
14
Rep 296
TO IMoY:
From reading the LED bulb websites, I recall that the heat in the resistor is normal. It is dissipating the extra heat it draws to fool the car into thinking that a full 5 watt bulb is installed. I also remember that they said you have to be VERY careful where you place the resistor: You are supposed to mount it on METAL on a flat surface so that the metal surface acts as a heat sink and that you are NOT supposed to put the resistor near anything that can melt. So, just check your location. You might have to move it slightly. Confirmation Question: So, you did NOT get any fault codes from the SIDE marker lights or the footwell, domelight, etc., lights on the inside. That is GREAT, because getting a YELLOW or ORANGE side market light in the LED's would look cool. Since these things are $2 a piece, for $10 with shipping, you can throw them out if you don't like them. My Mercedes has the marker lights in the side mirrors (they are LED), and they really catch people's attention when you are turninig so they don't turn in front of you. This is especially true when they are on the side of your car. The sites I went to were: superlumination.com (both LED and super white regular bulbs) and superbrightleds.com So, please confirm side marker lights don't give a fault. Thanks. Larry |
05-27-2006, 10:41 AM | #10 |
14
Rep 296
Oh, I forgot:
Attached is a WORD file that lists the type of every bulb in the 3 series. I thought people could use this information. Larry |
05-27-2006, 12:43 PM | #11 | |
Rep 123
Good luck! |
05-27-2006, 01:09 PM | #12 | |
71
Rep 858
Drives: 2010 e90 328i Msport
AW 2010 E90 LCI |
05-27-2006, 02:11 PM | #13 | |
Rep 123
05-27-2006, 05:06 PM | #15 | |
Rep 49
E90 330i | Deep Green | Beige Leather | ZPP | ZSP | 6 MT |Confort Access
09-10-2006, 11:31 PM | #16 |
24k GOLD
148
Rep 1,453
i guess ill use all the interior bulbs led and the license plate xenon. but anyone know what bulb is the one that shoots down oem amber when nothin is turned on. the twin lite that shoots down
09-11-2006, 12:12 AM | #17 |
302
Rep 1,928
Drives: had e90, 330i mystic blue
what is the # for the reading laps bulbs 194? I want to change my for LED's , adn what is the side of the dome lights ? and one last question does the intirior LED Dim
E90 Mytic Blue 330i 07-20-2006. 05-17-2011
Doesn't the idea of making nature against the law seem to you a bit . . . unnatural? Support NORML |
09-12-2006, 02:40 AM | #19 | |
Member
306
Rep 22,825
10-05-2006, 09:58 AM | #20 |
24k GOLD
148
Rep 1,453
anyone have diy pics of how to remove the license plate lights? i have trouble taking the cover out.
also caught a $115 ticket for parkin at bus stop trying to buy these bulbs at import shop. freakin could of brought the whole kit from bimmian |
10-05-2006, 01:16 PM | #21 |
Immunocal
Rep 44
Where are you buying LED interior bulbs?
I'll take your advices, I'm buying:
Led interior bulb kit. and For E90 Sedan 2 Bulb Kit Xenon Colored Filament Bulbs (License Plate Only) $12 IXB90AFLY Where can i buy LED interior Kit? How much are they? Thanks! CG |
