03-18-2008, 01:00 PM | #1 |
25
Rep 153
Exhaust System
Why BMW choose 2x pipes from the engine till the rear wheels and then convert to one pipe??? Why don't they convert to one pipe after the cats till the rear??? One pipe means less weight and better flow balance. Just think on a custom exhaust like this: 2x dp plus 1x mid-pipe till the tips with one big muffler in the center. There are very light weight mufflers like BURNS. |
03-18-2008, 01:44 PM | #2 | |
Rep 316
-Chris
MY00 S2000 #8712
03-18-2008, 02:40 PM | #5 |
25
Rep 153
But the point is, if they went to one pipe at the rear, why not to go with one pipe right from the dp??? There are a few 335i with 2,5"" straight pipes all the way (without cats, resonators and mufflers) and the sound isn't that bad, only a bit of drowning through mid rpm range. But with a muffler at the middle it will reduce that drowning.
03-18-2008, 03:38 PM | #6 | |
13
Rep 610
?? A car exhaust is there for a reason, with biturbos, it would be too restrictive to run a single pipe after the DP's. Again, the restriction would hinder the N54 and the added turbulence would further disturb the exhaust flow. There are two secondary cats, which is better than a single one. Isn't that obvious? Additionally, "drowning" is not the correct term, it is drone 'ing. And a second muffler will not correct it because the drone is a resonance or frequency inherent in a design of an exhaust, not because of the noise. The reason you replace a BMW engineered exhaust for an aftermarket one is because you want a less restrictive exhaust. That is hard to do and most aftermarket exhausts have gains ONLY when you remove the cats. Which is illegal, unless the aftermarket exhaust has been CARB/EPA certified. |
03-19-2008, 05:22 AM | #7 | |
25
Rep 153
1. From my experience, the E46 M3 has a two pipes from the engine to the rear. Supersprint smartly made one 3" pipe from the cats till the rear. With this they eliminate the x-pipe because the balance of the exhaust flow is now made in that one big pipe, and at the same time they saved some weight from the exhaust system. 2. It is obvious from the pic that i posted, that BMW converted to one pipe at the rear because of the lack of space, and by this they don't need an x-pipe in the 135i, like the 335i that has a two pipes all the way but with an x-pipe at the center for the reasons that i mentioned above. 3. If you are searching for the highest hp possible with money wisely spend, i'm suggesting with this thread a catless DP (like UR ~$600), then go custom with one 3" pipe (eliminates the 2nd cats) till the rear with one aftermarket muffler at the middle because is where you have more space under the 135i for a conventional muffler. For a less radical guy and to go really cheap, think in a 3" pipe at the middle (still eliminates the 2nd cats) till the oem rear muffler. I bet that a custom pipe like this won't go above $250, and the most restrictions of the exhaust flows is in the cats and not in the mufflers. My option 1 (fast and furious) is just for the weight savings freaks. |
03-19-2008, 06:22 AM | #8 |
Santa Fe Concorso
103
Rep 2,984
Tiago,
I felt Numb3rs was rude to point out your minor misuse of a word. I think your English is just fine for a 2nd language and I can understand your meaning with no problems. To answer: 1. Agree. The main advantage of a single 3" in most applications is weight savings. In the E46 M3 it also helped with the 'rasp' sound issue. 2. Agree completely. 3. Agree, and I think we will see the single 3" from downpipes back either from an after market company or likely first as a custom exhaust by a private owner. Maybe you? Should be worth a try. Some people may not want to eliminate all the cats on a street car, or even one pair, for legal or pollution reasons, which is understandable.
Santa Fe Concorso - The Southwest's Premier Automotive Gathering.
03-26-2008, 06:43 PM | #9 |
129
Rep 864
on the picture...correct me if I'm wrong...i see what i think to be 2 secondary cats down to 1 resonator then to the rear muffler.
Are there still "primary" cats on each down pipe that we cant see in the picture? Thanks |
03-26-2008, 07:14 PM | #10 | |
59
Rep 765
I've heard most people who eliminate the first set of cats with catless DPs, and keep the secondary set have still passed emissions tests. Imagine Titanium exhaust setups! mmmmm the weight savings. |
03-26-2008, 07:46 PM | #11 |
Rep 20
what diameter are the downpipes and when they become one what diameter is that? if two 2.25" pipes end up in one 2.5" or 3" single pipe further down the exhaust stream, it's better than coupling the hotsides of the turbos with 2.5" or 3" to begin with
03-26-2008, 07:52 PM | #12 |
59
Rep 765
DPs are 2.5".
03-26-2008, 09:25 PM | #13 |
129
Rep 864
so i take it that the primary cats are higher up on the DP to there point we cant see them in that pic....are there any pics of the the primary cat and DPs?
03-26-2008, 10:18 PM | #14 |
16
Rep 50
03-27-2008, 07:25 AM | #16 | |
36
Rep 1,329
03-30-2008, 07:01 PM | #17 | |
76
Rep 5,970
Also since the turbos are each being fed by 3 cylinder, they will be pulsing with the exhaust strokes. Maybe there was an issue with that pulsing that caused problems between the two turbos, and required the longer lenths of pipe. These are just guesses. I'm no exhaust or turbo expert. |
04-03-2008, 09:51 PM | #18 |
Rep 309
I believe for space considerations, if you look at the undercarriage if there was another resonator/catalytic converter it would disrupt the airflow from underneath.
Fully Restored 1985 Corolla GT-S
1987 328ci SR20DET Drift Car 1989 Honda Civic Si-R Current Project 2002 Corolla CE Daily Driver www.TheTunerSource.com |
