Radiator drain plug question E90
02-17-2024, 02:13 PM | #1 |
50
Rep 125
I am using a Nissens radiator replacement and am struggling on which side needs the shorter and longer side. I believe both plugs should be the shorter ones?
Also, does my car have the “after cooler” I have a small radiator that goes behind the main one but I don’t know what that is. I have a 2006 BMW 325i manual. |
02-17-2024, 11:23 PM | #2 |
Cometh
1092
Rep 1,308
Drives: Boy's Soul
Driver side: long plug if AT, short plug if MT
Passenger side: easiest way to verify if you have an "after-cooler" is to physically inspect your current radiator. If there is a hose connected to the radiator under the lower radiator hose, then you use the long plug. Last edited by The Nightman; 02-17-2024 at 11:40 PM.. |
02-17-2024, 11:37 PM | #3 | |
50
Rep 125
02-17-2024, 11:41 PM | #4 | |
Cometh
1092
Rep 1,308
Drives: Boy's Soul
I just replaced my radiator with the same Nissens one and had to use two long plugs since I have AT and an "after-cooler" |
02-17-2024, 11:44 PM | #5 | |
50
Rep 125
02-17-2024, 11:48 PM | #6 |
Cometh
1092
Rep 1,308
Drives: Boy's Soul
Yes, the plugs are very finicky and fragile. Screw the smaller drain plug in first to give the plug some more rigidity. Push them straight in and then turn it a quarter turn or so until it hits the stops and locks. I used a 19mm socket to push them in and a 19mm wrench to very gently turn them. Coating the o-rings with dielectric/silicone grease helps a lot
StradaRedlands4965.50 |
02-17-2024, 11:51 PM | #7 | |
50
Rep 125
02-17-2024, 11:52 PM | #8 |
4966
Rep 3,033
Drives: 2006 BMW 330i MT
Garage List 2006 BMW 330i [8.21]
2009 BMW 328i Touri ... [7.90] 2013 BMW X5 35i [7.63] 2011 BMW 528i [8.75] 2006 Mazda3 [5.50] |
Yes, short/short for a MT. I think it ships with long on driver side for AT, and short on passenger side for non-cooler. But don't quote me on that. Put it all together and if coolant gushes out from one of the sides, then you need the other plug!
02-17-2024, 11:53 PM | #9 |
50
Rep 125
02-18-2024, 12:00 AM | #10 |
Cometh
1092
Rep 1,308
Drives: Boy's Soul
I think Nissens needs to ship the radiator with either long+long or short+short for the most common applications. I'm not aware of any set up which uses long+short
02-18-2024, 12:02 AM | #11 | |
Cometh
1092
Rep 1,308
Drives: Boy's Soul
Have fun with the upper radiator hose connector! Or spare yourself the pain and just buy a replacement upper hose. |
02-18-2024, 12:04 AM | #12 |
50
Rep 125
Will do ahaha, I actually broke the short one experimenting so I’m in the process of finding a new one lol. Will come back here with any questions. Thanks for the help!
02-18-2024, 12:29 AM | #13 |
4966
Rep 3,033
Whichever way it was, it was the wrong one for me and I ended up spilling a bunch of coolant. But I figured it out eventually! Ended up breaking the longer diagonal tabs on the plug, but the shorter ones are still holding fine!
02-18-2024, 11:43 PM | #14 | |
Cometh
1092
Rep 1,308
Drives: Boy's Soul
How long have you had the Nissens radiator for? Hoping it lasts longer than the Behr ones. |
02-19-2024, 12:04 AM | #15 | |
4966
Rep 3,033
I have three in three cars, but all are under a year old, so no real longevity data to speak of. They're all fine though, so far so good! |
