Power steering problem.
02-06-2024, 08:30 AM | #1 |
46
Rep 418
I have a 2011 328xi and the steering feels like a tire is low. The steering is hard in the morning when I first drive the car in the moring then gets a little better later in the day. I don't know if the outside temperature is affecting it or not. The pump dosent make any noise and the fluid is OK. Has anyone ever had this problem?
Thank you |
02-06-2024, 05:47 PM | #2 |
Rep 18
Yeah, I think cold temperatures can affect power steering fluid and make it somewhat thicker, causing increased steering effort in the morning. Also, as the fluid warms up throughout the day and it can become more responsive.
02-06-2024, 05:58 PM | #3 |
4966
Rep 3,033
Drives: 2006 BMW 330i MT
Garage List 2006 BMW 330i [8.21]
2009 BMW 328i Touri ... [7.90] 2013 BMW X5 35i [7.63] 2011 BMW 528i [8.75] 2006 Mazda3 [5.50] |
Maybe siphon out as much of the old as you can and add fresh fluid? Do that a couple times till you've gone through the full liter of new. Can't hurt!
tcphoto3541.50 |
02-07-2024, 06:18 AM | #4 |
46
Rep 418
I'll try that. It just started doing it in the last few weeks. It been colder. The ravk has felt fine and not had any slop.
StradaRedlands4965.50 |
02-07-2024, 09:34 AM | #6 | |
4966
Rep 3,033
https://www.fcpeuro.com/products/bmw...zf-32416851218 |
02-07-2024, 01:17 PM | #7 |
150
Rep 324
If it's hard, easy, hard, easy as you turn the wheel. The u joint in the steering shaft may be binding and the culprit. If so spraying some penetrating oil then ATF on them may help free it up. I've done this on several of my BMW's and it works.
02-07-2024, 02:15 PM | #8 |
46
Rep 418
That's how it feels. I will try that before doing the power steering. I will replace the fluid and
reservoir if that dosent work. Thanks for the help |
