BMW 5-Series (G30) Forum 2017+ BMW 5 Series (G30) General Discussions Trunk Won't open with KeyFob or Rocker switch
      02-05-2024, 10:16 PM   #1
gongodefoy
Drives: BMW 540i
Hello all
My 2018 540i's trunk stopped opening with remote, inside rocker switch and trunk touch button. I have checked the valet switch located in the glovebox and that's set to unlocked. Also My key fob battery is new and the car starts up just fine. I opened the trunk with the emergency handle and the trunk motor seems to run and the latch grabs and closes the trunk. When the trunk is open i can see the latch function when i press the key fob truck unlock button. I have checked the corresponding fuses and they're all good.
Has anyone run into this issue, or have any ideas what to try next? Thank you
      02-06-2024, 08:54 PM   #2
padresu
29
Drives: g30
BMW 51248737952 Spindle Drive, Right
above is the part likely you need to replace. Mounted in trunk , R side, attached to trunk hinge and more or less tail light area, behind trunk wall finish, at front/above of fuse box, L side is spring loaded, R side is sprig loaded and power operated. Access is the same as to fuse box.
      02-06-2024, 09:38 PM   #3
gongodefoy
Drives: BMW 540i
thanks again buddy
5post
