03-01-2008, 12:20 PM | #3 |
No longer moderate
325
Rep 4,401
Remember the N54 utilizes direct fuel injection so the intake track is dry - all the way through. Not sure how that will inhibit the use of methanol, but the flame front of the cylinder head is predicated on the spray pattern of the direct injector. If you start introducing another source of fuel into the intake track arriving in a manner that isn't accounted for (in a place it shouldn't be), all bets are off - it will cool the intake but who knows what impact it'd have on the fuel burn process. Suspect there'd be easier gains with an uprated intercooler to be honest. Just my $0.02.
03-01-2008, 04:59 PM | #5 |
81
Rep 1,075
That's the real question. I seriously doubt WI would be worth the effort on a car that is stock. It might be worth trying on a car running very agressive aftermarket software. I don't know about you guys but I would not want to void my warranty on a brand new car. If I want to mod a car I'll keep an older one that's already out of warranty.
03-06-2008, 11:12 PM | #6 |
BMW ONE
15
Rep 630
Drives: 93 RX-7 R1, 135i
Helix will be making their own meth kit and a specific meth map for the attache:w00t:
135i - Alpine White - Black Leatherette - 6-Speed - Sport Package - Aluminum trim - 6FL
03-06-2008, 11:32 PM | #7 |
103
Rep 2,626
Meth also increases the effective octane of fuel, so it has benefits beyond just cooling charge temp. It lets you run more boost, more timing, and run things a bit further on the lean side.
'08 Black Saphire/Black Z4 M Coupe
RIP Gretta: Blue Water/Lemon 135i. Died to save me. -ChuckV |
03-07-2008, 10:28 AM | #8 |
BMW ONE
15
Rep 630
I'll just copy/paste what i put in the attache thread since their was a question about meth/water ....
Meth/water mix is a very cool thing. The water acts as a anti-knock since it can absorb crazy amounts of heat. Meth is super high octane. The misconception about this is that your spraying a straight liquid into the intake stream. The nozzles do a really good job of atomizing the liquid. Its like putting a humidifier in your house. The car just sees a really dense air. Any one that has lived on the east coast in the summer knows exactly what i'm talking about. Meth/water can give benefits to someone thats even running race gas. Plus the water keeps the engine really clean due to a steam cleaning affect. I have seen pics of motors that have used it and they look brand new when taken apart. Even on a daily driver. its a pretty inexpensive way to know your car will not be affected by any external temperature/humidity changes. The water/meth will even you out. $.99-$1.29 you can get 50/50 mix at most local walmarts...its washer fluid. Just get the pure mix with no additives. And that is all without a specific map. If you tune for it on a FI motor you can pick up some nice horsepower and torque
03-07-2008, 04:22 PM | #9 |
Mr. Brand Loyalist
41
Rep 418
We have used aquamist kits on many of our subaru,evo, and e36 turbo builds. The benefits are significant, however in order to run it safely your vehicle will need to be custom tuned with the met/water mixture you choose for optimum performance and reliability.
The other issue is the strength of the 135/335 engine block after 400whp. In many cases there have been issues with running more than 400whp (blown motors etc.) So with the intention of running software, meth, and turning up the boost levels to increase power beyond 400whp it is questionable the actual reliability of the engine.
Current: 1M, M2cs
Retired: '08 135i,550GTxDrive, etc. |
03-07-2008, 04:38 PM | #11 | |
Mr. Brand Loyalist
41
Rep 418
I was thinking of trying it on mine but what happens when I go into the dealer? Despite my friendship and past employment with them...either it will be in for a service and they'll see the extra tank in the trunk, or I use the existing washer fluid tank and someone fills it with washer fluid. Never mind the reliability and "who will tune it?" issue.
Current: 1M, M2cs
03-07-2008, 04:44 PM | #13 | |
Mr. Brand Loyalist
41
Rep 418
I'm not 100% sure if there would be another determining factor if using direct injection
Current: 1M, M2cs
03-13-2008, 05:02 PM | #14 | |
Rep 43
Works great, at least on the 2.0TFSI from Audi/VW. Meth injection is really useful only if you have tuning to take advantage of it. In the VW/Audi world you can run a 100 octane race gas map on 91 pump gas if you have meth injection. That equates to big HP gains and even bigger torque gains. (All the major chip tuners have switching devices that make it easy to change tunes via your OBD2 port) |
06-14-2008, 04:29 PM | #16 | |
Mr. Brand Loyalist
41
Rep 418
Current: 1M, M2cs
06-15-2008, 02:20 AM | #17 |
Rep 1
We (BSH) have been using methanol injection on our in house GTi 2.0T which has a direct injection engine for just about a year now. The combination has worked incredibly well for us and a before/after dyno session of my personal car while it was on the stock turbo revealed a 22 whp gain on the factory turbo. Now on an upgraded GT30 unit we have been able to push the car very hard even in the brutal heat of Arizona. (It was 110* today!)
Without making any changes to the tune already installed on the car, the VW ECM has had no problem trimming out extra fuel with methanol injection present. This has been verified by my on board wideband AFR gauge as well as by monitoring the AFR recorded by the ECM. Ultimately I would love a custom tune but unfortuneately that technology does not exist for the ME7 or the ME9 ECM's. Should the BMW ECM have this same capability then out of the box this will make a great power adder. However, if the BMW ECM does not have this ability then the air fuel ratio will certainly be rich. All said, methanol injection is an excellent way to increase performance on a forced induction vehicle and I am very happy to see it already being discussed for this platform. We are currently looking into purchasing a 135 and will definetly go that route should that become a reality. As we research the car I will be around the boards a bit so if there are questions on methanol injection I am happy to answer as long as the question/answer conforms to the rules of the site. -Phil |
06-15-2008, 08:18 AM | #18 |
No longer moderate
325
Rep 4,401
Phil - thanks for the update - technical talk and such can go where need be in the forums - sales talk should go in commerical forum.
Thanks for the tech info - it's appreciated!! |
06-19-2008, 11:33 PM | #20 |
Rep 309
YES! That would be great to produce higher boost output.
Fully Restored 1985 Corolla GT-S
1987 328ci SR20DET Drift Car 1989 Honda Civic Si-R Current Project 2002 Corolla CE Daily Driver www.TheTunerSource.com |
12-30-2008, 06:30 PM | #22 | |
21
Rep 513
09 135i montego blue 6speed..RR catch can,CDV,DCI intakes,stett charge pipe and tial bov, the above mods are not installed on my car, i just want to seem cool
Devils own water/meth dealer-PM me for info former car/ 2001 audi TT ~290bhp :w00t: |
