02-26-2024, 02:06 PM | #2 | |
F44 M235i
15
Rep 19
Drives: F44 M235i
Outlet can be anything really. It depends on how much you want to alter the rear bumper. Mine is a 78mm outlet. |
lucaslira1.50 |
08-13-2024, 11:23 AM | #3 |
Rep 3
Looks really nice. The tips inlet should be centered right? Does your car have that kind of flattened, “squashed” pipe inside the square oem tips? Did you need any cutting before fitting those quads? Thanks in advance!
08-13-2024, 01:38 PM | #4 | |
F44 M235i
15
Rep 19
Drives: F44 M235i
Yes, it should be centred and it was more oval, I had to cut back just to the point where it became completely round, the tips then fit perfectly and has just the right amount of clearance out the bumper. |
08-13-2024, 02:18 PM | #5 |
Rep 3
I appreciate your quick answer. I imagined it needed to be one of the oval ones. If it’s not too much trouble, could you share a link for the tips? Thank you!
08-13-2024, 02:26 PM | #6 | |
F44 M235i
15
Rep 19
Drives: F44 M235i
The tips are round. The original pipe is the "squashed" oval pipe. I cut the original pipe at the point it turned round so the tips fit over properly. I see you in the US. I am in South Africa so the link for here won't help much. But you can have a look at what i bought. Hopefully the link works. Akrapovic Takealot |
08-13-2024, 05:31 PM | #7 | |
Rep 3
Shra1ZN15.00 |
