01-31-2024, 04:12 PM | #1 |
Rep 12
Disconnecting power
Hi all,
I'm planning on removing headrest with active head restraint, and thus disconnecting power on 530d. Is it enough to disconnect only main battery, or I need to also disconnect aux one? Or you think battery should not be disconnected at all for this one? |
01-31-2024, 04:25 PM | #2 |
7448
Rep 6,820
Drives: '18 M550i|'21 X5|'03 540i
Garage List 2013 VW Tiguan [0.00]
2015 Infiniti QX60 [0.00] 2021 BMW X5 [0.00] 2003 BMW 540i [0.00] 2018 BMW M550 [10.00] |
Just the main battery in the trunk. I assume you’re just swapping in a new charge unit?
2018 M550ix|Carbon Black|Dinan Modifications|2003 540i|Jet Black|M-Sport|2021 X5 Mineral White
Prior BMW's: 1987 325e|1993 740i|1998 740il|2001 530i|2002 745li|2007 750li|2006 750li|2001 530i|2012 535xi| |
01-31-2024, 05:17 PM | #4 |
7448
Rep 6,820
When you pull the negative on the battery, the car will go to sleep. No need to wait. Honestly, I’m not even sure you need to pull the main battery, but it certainly can’t hurt to be safe. The aux battery is fine to leave connected.
02-01-2024, 08:48 AM | #6 | |
4495
Rep 7,538
There was too much info to capture...so I just have a little bit of the info for removing the ACTIVE head restraints. If you don't have the active head restraints...then no, you don't need to disconnect the battery.
2015 F06 650ix Gran Coupe`(Moonstone/Cohiba Brown)| 2014 F15 X5 50i MSport (Space Gray/Mocha)
Become a BMW CCA member! Click HERE to join and feel free to use my BMW CCA member #191509 as a referral. Last edited by Qsilver7; 02-01-2024 at 08:58 AM.. |
02-01-2024, 12:28 PM | #7 |
Rep 12
I will not be removing catridges or anything related to active restraint. Will only remove whole headrest and give it for painting. Will disconnect both batteries anyway. Is there any special sequence, or just remove negative lead from main battery and then from aux battery? Thanks
02-01-2024, 02:47 PM | #8 |
4495
Rep 7,538
Just remove negative leads from batteries and either tie them back or make sure they don't touch anything metal. Since there's a pyro charge that explodes in an accident that moves the headrest forward...its probably connected to the SRS system...which if the headrest is like the seat belts...they can create an airbag warning light if disconnected when the battery is powered. So make sure you don't reconnect the battery until the headrest is plugged back in.
I usually wrap a rag around them or use my yard gloves if I'm working in the garage. When I was younger...I may have grabbed an old pair of stretched out athletic socks to protect the battery cable from shorting against metal. But they were the old long socks back then.
Become a BMW CCA member! Click HERE to join and feel free to use my BMW CCA member #191509 as a referral. |
Joe-BMW337447.50 |
02-18-2024, 08:20 AM | #9 |
Rep 4
Hi expert,
Help needed !!! I disconnected my car battery and turnk closed by mistake What is ur advice to open it again Car model is BMW 520 i 2018 Thanks in advance |
02-18-2024, 12:59 PM | #10 | |
4495
Rep 7,538
If you kept the BST intact and didn’t completely disconnect it from the positive battery cable in the trunk…you should still have power once you connect to the terminals in the engine bay. You can then use your remote or the interior trunk release button to open the trunk.
