02-25-2008, 11:43 AM | #1 |
Moderator
369
Rep 4,745
Weights for stock wheels and tires.
Bridgestone RE050A RFT tires are standard on the 135i.
The 215/40/18 front tire weighs 23.8lbs. The 245/35/18 rear weighs 26.0lbs. Per member TP 135i the weights on the 264's are below. Front wheels are 11kg (24.2 lbs) Rear and 11.92kg (26.2 lbs) http://www.1addicts.com/forums/showthread.php?t=4632 Stock wheels and tires together: 48.0lbs each on the front 52.2lbs each on the rear.
Gary. Tire and Wheel Forum Moderator. Tire Rack Sales Rep Gary@Tirerack.com
http://www.tirerack.com/a.jsp?a=AH8&url=index.jsp Please refer to 'Gary/E90 Post' as your previous contact when you order online to help support this forum. |
02-25-2008, 11:51 AM | #2 |
Santa Fe Concorso
103
Rep 2,984
Thanks, Gill.
Santa Fe Concorso - The Southwest's Premier Automotive Gathering.
03-05-2008, 12:28 PM | #4 |
BMW ONE
15
Rep 630
Drives: 93 RX-7 R1, 135i
Go to the individual's tire specs on tire rack.com they will list the tire weights.
135i - Alpine White - Black Leatherette - 6-Speed - Sport Package - Aluminum trim - 6FL
03-11-2008, 11:16 PM | #9 |
BMW ONE
15
Rep 630
lets us know how you like the tires seems like a good choice
03-12-2008, 02:19 AM | #10 |
PCA, BMWCCA
102
Rep 2,058
Leads me to believe perhaps the wheel weights for the 264s posted in the first post are inaccurate. Seems the 261s should weigh roughly the same if not lower, and the conventional tires for sure weigh less than the OEM runflats.
'08 Carrera S 6MT Guards Red/Black ext leather, Carbon fiber pkg, sport exh, sport chrono +, PASM, Nav, Bose, 19" forged turbos, red tranny tunnel
'07 MV Agusta F4 1000 R 1+1, Corse Red/Silver, RG3 race pipes and factory race ECU |
03-12-2008, 07:11 AM | #12 |
29
Rep 1,340
Drives: 2008 135i SGM MT
Garage List 1995 Acura Integra SE [0.00]
2008 BMW 135i [0.00] 2006 Porsche Cayman S [0.00] 1999 Toyota 4-Runner [0.00] |
FYI
The wheel weights I posted earlier are from this site http://felgenkatalog.auto-treff.com/ 261s = 11.8 / 11.23 kg (18 x 7 f / 18 x 8.5 r) 264s = 11.0 / 11.92 kg (18 x 7.5 f / 18 x 8.5 r) I don't know why the 261s are listed for 7" wide fronts. And now that I look at the numbers they don't make much sense do they? JAMS 135 Did you weigh the stock wheels / tires before the switch ???????
2008 135i SGM |
03-12-2008, 07:22 AM | #13 |
2148
Rep 10,176
Very nice looking setup! Even with going to a larger tire, you'll shave a few pounds of unsprung weight off of each corner by getting rid of the runflats... I can't wait to see the subtle difference in the larger tires in the wheel well.
Please take some before and after pics! |
03-12-2008, 07:25 AM | #14 | |
2148
Rep 10,176
Jams doesn't even have his car yet.. just like the rest of us in the States. |
03-12-2008, 07:41 AM | #15 | |
29
Rep 1,340
Well hopefully he will weigh them when he gets his car. I feel so dumb now...
2008 135i SGM |
03-12-2008, 07:59 AM | #16 | |
PCA, BMWCCA
102
Rep 2,058
03-12-2008, 09:13 AM | #17 |
Moderator
369
Rep 4,745
Not everyone is out for weight savings. If he likes the look of the 261 better, it's a great reason to switch.
03-12-2008, 09:27 AM | #18 |
PCA, BMWCCA
102
Rep 2,058
Yes of course and these things are personal choices. Unfortunately BMW NA gouges you in the process. Seems you should be able to order the car with any OEM wheel BMW approves fitment.
03-12-2008, 09:55 AM | #19 |
29
Rep 1,340
I'm actually considering (haven't made up my mind yet) swapping out the stock 264s for the 261s. And this is purely for cosmetic reasons. I just love the 261s. Now after the swap I'll attempt to reclaim maybe 50% to 75% of the cost by selling the 264s to someone that would like that upgrade.
Now, having said that, I also want to wait a while and see what becomes available in the aftermarket wheel selection which would give me a different look and save weight in the process. To be continued... GIL.............you are listening, right?????
2008 135i SGM |
03-12-2008, 01:21 PM | #20 |
Rep 186
Thanks for the "edit" button tip, Turbomg... I learn something every day.
It's mostly emotional for me. I like the look of the 261s better and the car will look the way it does most everywhere else in the world, when equipped with the sport package. Besides, I hate RF tires.. my MCS was transformed when I switched to NRF RE050A tires. Having said that, I will definitely weigh the stock wheels when they come off... if there is a weight advantage to my setup; all the better. As far as the stock wheels and tires, maybe someone will want a deal, otherwise, I will store them until I move on to something else and put them back on then. |
08-15-2013, 12:43 PM | #22 |
47
Rep 327
Drives: 2012 BMW 135i
Best thread I could find, even if it's 5 years old. So by math, from TireRack:
261M wheels--Front 52 lbs - 26 lbs 225/40/18 RE760s = 26 lbs. Rear 54 lbs - 26 lbs 245/35/18 RE760s = 28 lbs. Oddly enough, TireRack says the current Dunlop RFTs are 24 lbs. 215/40/18 and 27 lbs. 245/35/18 (stock specs). I thought RFTs would weigh more. This means stock setup for MSport package folks with 261M wheels is 50 lbs in front, 55 lbs in rear, total wheels + tires. |
