The Tire Rack
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Suspension | Brakes | Chassis > Squeaking/spinning when braking
      01-23-2024, 07:52 PM   #1
Amazed
Drives: 335i E93 M Sport
Hoping someone can diagnose this as myself and my mechanic can't.
Recently whenever I brake (especially downhill) there is a high pitched squealing/spinning sound towards the end of braking and shortly after completely stopping.
It sounds like a bearing or belt. This happened not long after an accessory belt replacement but everything looks OK there.
https://drive.google.com/file/d/1Fdi...ew?usp=sharing
Stock E93 335i 2007 N54 other than a JB4. Has anyone experienced this?
Thanks
      01-25-2024, 02:23 PM   #2
crashoverride
178
Drives: na
I had to replace all of my wheel bearings at around 160k miles. It squeaked while on the freeway. It's a pretty inexpensive and quick repair.
But squealing when braking usually indicates the brake pads need replacing
      02-05-2024, 08:17 AM   #3
Scubudo
29
Drives: 2011 BMW 335D
2011 BMW 335d  [0.00]
After watching the vid, I agree with you that it isn't the brakes (because it appears to happen right after you come to a complete stop).
It sounds like one of the belt driven pulleys to me. So If I couldn't locate the source, I would start with changing the tensioner and idler pully (because it is fairly cheap and simple)
Before that I would check the motor mounts, and everything just in front of the belts for contact with a pulley or belt (since it is possible that the inertia of the stop could allow a little foreword movement of the engine causing something to rub.
It will be interesting to know what you find as the cause.
      02-12-2024, 11:26 PM   #4
Amazed
Thanks, your assessment makes sense and would explain why it’s worse downhill. We’ll check for all of that this weekend. If we find/fix the problem I’ll share an update here
      02-19-2024, 10:06 AM   #5
Jaronbwall
Driving cars and riding bikes really fast
Jaronbwall's Avatar
285
Drives: 2009 335i
My car recently developed a lip on the edge of the front brake rotors causing a similar noise at slower speeds. It's rubs on the pad just slightly and it's very annoying. Time for new rotors. Wheel bearing can make rolling/grinding sound if they go bad. Lift your car and check for these things.
335i, sport pkg, 3 pedals, Blacked out, LED markers, OZ Ultraleggera wheels, Firestone Indy 500s, x-pipe, vibrant 1792, PE mod
MHD stage 2+, BMS DPs, ARM charge pipe, Tial BOV, ARM FMIC, dual cone, CSF radiator, M3 control arms, sways, HAWK pads.
https://www.strava.com/athletes/8309149 Follow me on Strava
