      02-22-2008, 04:05 PM   #1
john970
1er
73
Drives: 08 135
245/45R18's fit on rear stock 18's?
Will a tire 245/45R18 fit on the rear stock 18" rims on the 135i? I know they will fit on the wheel, but is the slightly larger tire ok?
Trying to avoid buying new wheels. The hankook W300's don't come in 245/35R18
http://www.hankooktireusa.com/product/W300.pdf
edit: they don't make the right tire size for the fronts either, i give up...
      02-22-2008, 05:31 PM   #2
mikeo
Santa Fe Concorso
mikeo's Avatar
103
Drives: '11 M-sport 328i, '13 X1 28i
John, go with 225x40-18 (or 225x45) at all four corners with the stock wheels, it'll work fine. 245x45 is too tall a tire for the rear.
Santa Fe Concorso - The Southwest's Premier Automotive Gathering.
      02-22-2008, 07:16 PM   #3
PrematureApex
840
Drives: N55 X1, N54 135, s54 m3
Its slight % increase in diameter...
It will most certainly fit. Yes, his speedo will be a little off, his acceleration a bit slower...but these are winter tires, so performance isn't really an issue.
If you're on a budget, and like the tires, there's no reason you can't go with them.
      02-22-2008, 07:41 PM   #4
mikeo
Santa Fe Concorso
mikeo's Avatar
103
I would disagree with you there, PrematureApex. The diameter delta between a 245x35-18, the OE size, and a 245x45-18 is +1.6 inches. Not a trivial amount. From experience with another model BMW I can state that increasing tire diameter by over one inch could lead to interference with the wheel well or fender liner.
      02-22-2008, 07:46 PM   #5
larryn
2146
Drives: '97 332ti, '21 X5 45e, '16 GT4
Not to mention it might interfere with the traction control, since the rear wheels would be spinning at a different rate than the fronts...
      02-22-2008, 08:49 PM   #6
BMWeber
36
Drives: 08 135i
same experience here. especially on the front the way the spring perch is(especially on smaller BMWs) you have very little room for increased diameter. I had an 88 325ix where you had less than a 1/4"
      02-23-2008, 08:31 AM   #7
PrematureApex
840
I thought we ran 40's out back. I"m still in 17" world over here. My apologies.
That's a lot to deal with.
Further, I of course would assume he'd be sizing the fronts up as well. But anything over 1" makes me nervous.
      02-23-2008, 08:36 AM   #8
mikeo
Santa Fe Concorso
mikeo's Avatar
103
Agreed.
1addicts
