      02-17-2008, 11:03 PM   #1
JohnL135I
Donkey Kong King
89
Drives: 2012 Boss 302
Where's the 12volt plug(lighter plug)??
Where is the lighter plug (12 volt plug) in the 135i?? Just wondering where I will put my radar detector power adapter....
thanks
      02-17-2008, 11:54 PM   #2
Twisted
TwistedHouse
Drives:
It depends if you'll be adding the storage compartment package i think.
Otherwise there should be one underneath the armrest (in between the 2 seats) and one in the ashtray in front of the gearstick.
      02-18-2008, 10:27 AM   #3
mikeo
Santa Fe Concorso
mikeo's Avatar
103
Drives: '11 M-sport 328i, '13 X1 28i
You're not considering hardwiring it?
Santa Fe Concorso - The Southwest's Premier Automotive Gathering.
      02-18-2008, 09:29 PM   #4
Year1of1
Year1of1's Avatar
32
Drives: 2020 X5 M50
does bmw do that?
2008 128 - retired
2010 X5 - retired
2013 535 - retired
2015 X1 - retired
2020 X5 M50i - On Order
      02-18-2008, 10:36 PM   #5
mikeo
Santa Fe Concorso
mikeo's Avatar
103
I can pretty much guarantee there will be Do-It-Yourself instructions on 1Addicts within a matter of days after the 1-Sereis is released. Or, take the DIY info to an car audio shop, they'll hardwire it for you.
      02-19-2008, 09:51 PM   #6
djmBMW
djmBMW's Avatar
Drives: 135
Hardwire is the way to go, but make sure it's a switchable circuit so it turns on and off with the ignition. On my MINI I tapped into the heated seat fuse. Hope to do same with 135.
      02-19-2008, 10:03 PM   #7
slipkmaggot
15
Drives:
but u can't do that if u lease your car right?
:roundel: :roundel: :roundel: :roundel: :roundel: :roundel: :roundel: :roundel: :roundel:
      02-20-2008, 09:14 AM   #8
Sherifftruman
Drives:
Well, some places sell connectors that you can plug in to another connector under the dash that allows power to be taken off at that point. Those are completely removable. In some cars, ther eare also unused connectors that you can get power from just by installign a fuse, depending on the options you got.
Like someone else said, I'm sure people will figure this stuff out pretty quickly after the cars are available.
      02-20-2008, 09:53 AM   #9
larryn
2146
Drives: '97 332ti, '21 X5 45e, '16 GT4
Radar detector harwire DIY from e90post.
It's completely reversable, and fairly easy to do...
      02-20-2008, 10:55 AM   #10
JohnL135I
Donkey Kong King
89
Yes, I plan on doing the hardwire complete install. But initially I'll be using the cord/lighter plug.
      02-20-2008, 03:13 PM   #11
C_Topher
Seņor Member
16
Drives: 135i
I hear BB and CC will do it for $25.
      02-20-2008, 05:27 PM   #12
d3syd
d3syd's Avatar
Australia
50
Drives: 135i MT, LMB, ProNav
2008 135i Coupe  [0.00]
Yes I was pondering the same question as well. With the lighter plug located under the arm rest instead of the dash like most cars, the lighter cord has a long way to stretch to the detector on the windscreen. Looks like hardwiring is the way to go.
Fun Car: 135i Manual LeMans Blue / Beige Leather / Grey Poplar / pro nav / euro plates. Delivered 24 June 08
Family Car: Land Rover Discovery 4 SDV6
Spare Car:
Volvo V70 Sydney Car: MB 420SEL
      02-20-2008, 06:28 PM   #13
larryn
2146
Is it different for you 'others' down under? :wink: Here we get one under the armrest, and one in the ashtray, right at the dash.
      03-09-2008, 01:14 PM   #14
135iowner
135iowner's Avatar
Drives: 135i / 1M on order
Question
Can u remove the radar if it is hardwired? Don't want some punk smashing my window for a radar detector.
      03-09-2008, 01:55 PM   #15
larryn
2146
If the detector unplugs at the detector itself (like pretty much every one I've seen), then yes, it is removable.
      03-09-2008, 02:45 PM   #16
asv
44
Drives: 135i
I ordered a hardwire kit and concealed display for my V1 today, I will probably install it next weekend assuming I get my car Saturday.
      03-18-2008, 01:47 PM   #17
MZWIE
388
Drives: M2
Guys. Hardwiring in BMW's is really easy. Using a voltmeter locate an unused spot in the fuse box, turn on the ACC and determine which one is on. Use a standard spade lug on the power wire in question and slide onto the unused fuse location. For the ground any metal surface will do. Just find a screw and put the ground wire on it. That's it.
Takes all of ten minutes maybe.
1addicts
