Closed Thread
      02-15-2008, 07:38 AM   #1
mikeo
Santa Fe Concorso
mikeo's Avatar
103
Drives: '11 M-sport 328i, '13 X1 28i
Exclamation N54 Technical Service Bulletins
SI B11 02 08
Engine February 2008
Technical Service
[Sorry, no Graphics]mikeo
SUBJECT
N54: Power Reduction - DME Fault 2A82 VANOS Inlet is Stored
MODEL
All E60, E61, E90, E92, E93 with the N54 engine from SOP
SITUATION
The "Service Engine Soon" (MIL) lamp is illuminated and a power reduction is clearly perceptible. This situation may occur after driving for some time with the engine already at full operating temperature. If the ignition is cycled, the engine then usually performs normally.
The following faults are stored in the DME:
2A82 VANOS intake - stiff; jammed mechanically - fault currently not present - fault would cause warning lamp (MIL) to light up
3100 Boost-pressure control, deactivation - Boost-pressure buildup prohibited - fault currently not present - fault does not cause warning lamp (MIL) to light up
CAUSE
The VANOS fault is usually caused by an insufficient oil pressure supply to the inlet VANOS adjustment unit.
To effectively move the camshafts to the target positions, in the specified time and under all engine conditions, sufficient oil pressure supply to the VANOS control pistons must always be available.
When the engine operation requires that VANOS quickly advance the intake camshaft, fault 2A82 may be set if the intake camshaft is "late", or does not reach the target position. In this situation, engine power may be reduced and a check control message displayed. The consequential fault 3100 can also be set in the DME fault memory as well.
If this fault is stored under these conditions, the possible cause is that the camshaft hook ring seals (3) have worn a groove into the camshaft bearing ledge (1), causing a drop in oil supply to the VANOS unit.
[GRUSB1107U79.JPG]
Camshaft bearing ledge
Intake camshaft
Hook ring seals
[GRUSB1107U78.JPG]
Note the deep grooves worn into the intake camshaft bearing ledge by the camshaft hook ring seals.
[GRUSB1107U77.JPG]
Acceptable camshaft bearing ledge – minor wear marks from the rotation of the camshaft are normal.
If excessive wear to the camshaft bearing ledge is found, it is only necessary to replace the intake camshaft sealing rings and the intake camshaft bearing ledge.
PARTS INFORMATION
Part Number
Description
Quantity
11 31 1 705 512
Intake camshaft hook ring seals
11 12 7 550 913
Intake bearing ledge
WARRANTY INFORMATION
Covered under the terms of the BMW New Vehicle Limited Warranty.
Defect Code
11 31 21 26 00
Main Work*
Labor Operation:
11 31 028
Removing and installing or replacing
Labor Allowance:
Refer to KSD
*Main Work:
Use this labor operation number when this is the only repair being performed, or if this is the main repair when performed along with other repairs at the same time. If this is not the main repair, refer to KSD for the associated (+) labor operation code.
[ Copyright © 2008 BMW of North America, LLC ]
Santa Fe Concorso - The Southwest's Premier Automotive Gathering.
      03-11-2008, 01:36 PM   #2
mikeo
Santa Fe Concorso
mikeo's Avatar
103
SIB 11 13 07 - N54 Rattle Noise from Turbo Area
Technical Bulletin from November, 2007.
http://www.bmwtis.com/tsb/bulletins/...p/B111307g.htm
      11-05-2008, 02:28 PM   #3
mikeo
Santa Fe Concorso
mikeo's Avatar
103
SIB 62 01 08 October 2008 - Cruise Control, New Progman version
Refer to this link for details:
http://www.bmwtis.com/tsb/bulletins/...p/B620108g.htm
Closed Thread
Search this Thread:
Advanced Search
1addicts
