02-07-2008, 07:29 AM | #2 |
Moderator
556
Rep 4,240
Pretty expensive tire. My s2k came with them stock. It wore pretty quickly too. Anyway, it was a GREAT handling tire.
- 04 Honda S2000(gone)
02-07-2008, 08:23 AM | #3 |
2146
Rep 10,176
We'll likely get RE050A runflats from the factory anyway. Almost every one of the 18" wheel equipped cars that I've seen from BMW (non-M) generally have those.
02-07-2008, 09:11 AM | #4 |
Zoom Zoom
38
Rep 1,069
Most likely. Either them or the Dunlop SP Sport 01 DSST. I had the Bridgestones on my Mazda at first and they were a decent tire. But they are expensive and wear poorly. There are a whole raft of great performance tires that will be cheaper than the Bridgestones.
In the garage: 2022 G80 M3 Manual - Portimao Blue
02-07-2008, 10:25 AM | #5 |
Rep 90
Not likely. It is sure, I got that tires from factory in my 135i and you will not get other tires simply because they are a special version of the RE050As with low rolling resistance specially designed for BMW. It is very unlikely that BMW has arrangements with other tire manufacturers.
02-07-2008, 03:00 PM | #7 |
Rep 90
Yup. Tire dimensions are very weird too. BMW should have specially requested that size for this car.
02-07-2008, 03:04 PM | #8 |
2146
Rep 10,176
Forces you to go a bit wider and reduce understeer. 225s will fit the stock front wheels, 255's on the rear. You have oddles of choices then. :wink:
02-07-2008, 06:01 PM | #10 |
Moderator
556
Rep 4,240
I like that approach.
02-07-2008, 08:06 PM | #11 |
Santa Fe Concorso
103
Rep 2,984
It'll work fine.
Santa Fe Concorso - The Southwest's Premier Automotive Gathering.
02-07-2008, 09:45 PM | #12 |
601
Rep 836
jams, i'm looking to hook up a set of 261s as well. i'm still inquiring across many dealerships to see if it's possible. if not, i bet we could hook something up w/ a fellow 1addict. either way, i'm planning on ps2s personally. if you do find out a way to get some 261s, please pm me. i'll do the same. thanks.
02-07-2008, 10:06 PM | #13 |
Rep 186
confusion: I spoke with my dealer today. They have part numbers and pricing but can't order yet. I hope to get the wheels and tires before the car arrives in March. After a little research, I am leaning towards the Bridgestone RE 010R. I will drop you a note when they place the wheel order... shouldn't be more than a couple of weeks, they said.
Here are the 261 part numbers and retail prices: 36 11 7 891 050 Front $470 each 36 11 7 891 051 Rear $505 each |
02-08-2008, 06:51 AM | #16 |
Santa Fe Concorso
103
Rep 2,984
Thanks, JAMS 135. The Bridgestone RE 01R is a top performing summer tire, for sure. Just don't expect very long wear from them. It's one of the favorite tires for SCCA Solo street tire classes.
02-08-2008, 10:49 AM | #19 |
2146
Rep 10,176
Interesting. The Existing RE750 looks nothing like that...
Edit: Found it.. it's the RE 070 (as seen at tire rack): Getting bad reviews, and is OEM for Subaru WRX |
02-08-2008, 11:52 AM | #22 |
Moderator
369
Rep 4,745
Are you sure it's not the new RE760?
Gary. Tire and Wheel Forum Moderator. Tire Rack Sales Rep Gary@Tirerack.com
http://www.tirerack.com/a.jsp?a=AH8&url=index.jsp Please refer to 'Gary/E90 Post' as your previous contact when you order online to help support this forum. |
