01-03-2024, 10:07 AM | #1 |
Rep 3
BMW F30 LCI Headlight change
I have a BMW F30 (12/2015) LCI with Halogen Lights, and I want to swap them with normal LED lights. I found a cheap pair from another BMW F30/F31 LCI model and wanted to know if the installation will be easy and if my car support LED lights without needing to change any pins or anything else.
01-03-2024, 10:35 AM | #2 |
2478
Rep 1,833
if you have halogen lights it would be easier, and probably cheaper, to go with aftermarket LED headlights. they make a version that plug right into the halogen connection, so you don't need to do any wiring modifications. I believe LED headlights are not plug and play with your car if you go the OEM route.
01-03-2024, 03:25 PM | #3 | |
Rep 3
01-03-2024, 03:29 PM | #4 | |
2478
Rep 1,833
you also don't need those modules if you go aftermarket. As far as making the connections work with your car that came with Halogens, I don't know the exact answer to that unfortunately, maybe someone else can answer.
01-06-2024, 07:08 AM | #5 | |
Rep 3
01-06-2024, 07:21 AM | #6 |
2478
Rep 1,833
yeah both standard and adaptive have modules. they technically both use the same set of modules, same part numbers. i believe there’s 4 of them.
