2010 2011 BMW 5 Series Forum F10 N55 Oil cooler gasket woes |
12-28-2023, 03:00 PM | #1 |
252
Rep 333
Drives: F10 535i xDrive, F25 xDrive35i
Over the last 20k miles, I’ve replaced the oil gasket cooler three times. Of note, I used OE gasket and followed the procedure, and torqued the bolts correctly.
And then it dawned on me. The failure has been the exact same each time. It fails at the bottom bolt area just above the belt tensioner. So this time I did a more thorough investigation. See the attached photos. The circled area is chipped and damaged, right where the leak has occurred the last 3 times. I can never keep this oil cooler dry! Do you think this little damage can cause this issue? This time around, I replaced the gasket again with brand new bolts and torqued corretly. If it leaks again, I’ll have high suspicion it’s from this small damage. But the question then becomes, how did it get damaged?? |
12-30-2023, 07:20 PM | #2 |
5020
Rep 3,072
Drives: 2006 BMW 330i MT
Garage List 2006 BMW 330i [8.25]
2009 BMW 328i Touri ... [8.00] 2013 BMW X5 35i [7.80] 2011 BMW 528i [8.70] 2006 Mazda3 [5.50] |
I have a bad feeling for you that that is the problem. That's the coolant portion, are you the original owner? If it's corroded like that, the wrong type of coolant may have been used causing it over time.
12-30-2023, 07:48 PM | #3 |
252
Rep 333
No I’m not the original owner but I did change the water pump and used OE coolant with a recent flush. I’m thinking if it leaks again then this is likely the problem.
12-30-2023, 07:54 PM | #4 |
5020
Rep 3,072
Do you remember the color of the coolant back when you did the water pump? Doesn't have to be the cause of it, but it could be.
12-30-2023, 08:27 PM | #5 |
252
Rep 333
12-30-2023, 09:44 PM | #6 |
5020
Rep 3,072
12-31-2023, 05:22 AM | #7 |
541
Rep 1,876
IMO, the housing is not a highly expensive part (compared to the cost of even DIY time to do this job multiple times). You've identified that it keeps leaking from a spot where there is a clear defect in the housing, whatever the cause - just replace it.
Shop around for the best price on a genuine or OE part and pull the trigger Again, just IMO. |
StradaRedlands5020.00 cdmulders330.50 |
12-31-2023, 08:54 AM | #8 | |
252
Rep 333
StradaRedlands5020.00 |
12-31-2023, 01:42 PM | #9 |
541
Rep 1,876
01-14-2024, 09:46 PM | #10 |
230
Rep 457
I've seen leaks because of stripped threads. They are often over-tightened, and I am guilty of such. Torque to spec. If stripped, replace housing. Those threads in your pic don't look so good. Keep us posted.
04-17-2024, 07:56 PM | #11 |
252
Rep 333
I thought I’d put an update. I replaced the entire OFH both cooler and block side, new bolts, new gaskets, and oil temp + it’s gasket. It’s been about 1000 miles…No leaks! Altogether parts were about $600 from fcp and I did the work myself. It wasn’t a horrible job.
ChiltiCoatl891779.50 StradaRedlands5020.00 |
04-19-2024, 11:56 AM | #12 |
23
Rep 21
Thanks for following up on this Houranimd49. I'm getting ready to tackle mine in a couple of weeks. From the pictures, it looks to me like someone had dropped it while it was off the vehicle previous. Just a guess......
2011 BMW 535i, 6spd, Milano Beige Metallic, Venetian Beige Leather, Convenience Package, Premium Package 1, Premium Package 2, and Sport Package. 119,500+ miles.
