01-07-2008, 09:58 AM | #1 |
Constantly Learning
66
Rep 200
Turbo Lag from Piggyback or Flash?
A thread that was previously locked had a couple posts concerning lag from adding the PROcede. I thought it was best to clear this up. It seems that many people are new to turbo cars and confused to what the electronic mods to. Below you can clearly see the power curves of a car (stock than PROcede). There doesn't appear to be any lag - just gobs of power. This was taken from an e90post thread - http://www.e90post.com/forums/showth...=V2+Dyno+stock
Thought I would share. |
01-07-2008, 10:15 AM | #3 |
Santa Fe Concorso
103
Rep 2,984
Gobs of power is right! Aren't turbos wonderful?
Santa Fe Concorso - The Southwest's Premier Automotive Gathering.
02-12-2008, 01:20 AM | #5 |
458
Rep 4,822
But stock is substantially better than Procede up to 2500rpm, which could account for a lot of start and stop city driving. Other ECU reflash like the one on my GTI has better power and torque almost all the way from 1300rpm from memory.
02-17-2008, 08:02 AM | #6 | |
2146
Rep 10,176
In that other closed thread, I had mentioned a few times that there was a definite, perceptible lag form when you hit the accelerator to when you get power on an autocross course...
I just read a new thread on e90post that backs that up: Quote:
It seems that this new aftermarket diverter valve removes a lot of that initial hesitation. I did NOT post this to open the proverbial can 'o worms, but to state that the tunes that I drove (v1.47 and v2) did have that feeling of lag, backed by dyno or not. :smile: |
02-17-2008, 08:15 AM | #7 |
Santa Fe Concorso
103
Rep 2,984
I doubt a chasis dyno would show the issue you have experienced, Larry. Chasis dynos aren't great duplicators of the real-world. Is that the Forge diverter valve?
So what, exactly, do we think is happening to cause that significant hesitation with chipped cars vs. stock in an on-off-on throttle sequence?
02-17-2008, 08:16 AM | #8 |
2146
Rep 10,176
Yes it is. I may wind up getting one, if we see a few more posts like that one... It's relatively cheap too, at ~$335. I wonder if the one for our cars will cost ~$135.
02-17-2008, 08:22 AM | #10 |
Santa Fe Concorso
103
Rep 2,984
Here is and interesting review of the Forge DV by O-cha.
02-17-2008, 08:38 AM | #11 | |
2146
Rep 10,176
02-17-2008, 08:54 AM | #13 |
2146
Rep 10,176
Not sure. The area where this goes is quite a bit tighter on the 135i, than the 335i. On the 335i I've read it is about an hour to install. I'd expect it to take a good bit longer on the 135i, unless you can train your 3 month old kid with tiny hands to do it for you.
02-17-2008, 09:19 AM | #15 |
Santa Fe Concorso
103
Rep 2,984
Sorry for the double link, Larry.
I read some manufactruer's installation instructions for their piggy-back chip where they said that while the 335 install can be done completely from the top, the 135 requires removal of the under-pan and then install is performed from underneath the car. They mentioned that after taking 5-minutes to remove the under-pan the install was actually easier on the 135 working from the bottom (if you have a lift, anyway). I suspect we'll be under the car doing work more than 335 owners.
02-17-2008, 09:25 AM | #17 |
2146
Rep 10,176
Very true! The SSTT mod on the 135i requires you to get under the car, but it's still the simplest installing tune (other than the Dinan, which you simply drive up and have them reflash your car).
With the Dinan, if you don't have the oil cooler, they will install one for you (since they require it), for another $2000... |
02-17-2008, 09:27 AM | #18 |
Santa Fe Concorso
103
Rep 2,984
Remember the days when the 1955 Chevy V-8 looked small in the engine compartment? Nowadays you either have to own that trained monkey or be multi-double-jointed.
02-17-2008, 09:29 AM | #19 | |
Santa Fe Concorso
103
Rep 2,984
I'm still considering the Dinan flash, but only if our 135s have the factory oil cooler.
02-17-2008, 09:31 AM | #20 |
2146
Rep 10,176
Don't forget their $1600 intercooler upgrade while you're there... :biggrin: Totally worth it, if you want the Dinan badge on the back. :wink:
02-17-2008, 09:33 AM | #21 |
Santa Fe Concorso
103
Rep 2,984
Dinan should just sell us all their aftermarket 135 parts then just throw the car in as a freebie.
Don't misunderstand, I've bought many Dinan parts and think they are top quality stuff. But I thought the Stage 5 software for my E36 M3 was expensive at $900.
02-17-2008, 09:47 AM | #22 | |
No longer moderate
325
Rep 4,401
Here's a writeup of the valve on the Forge site:
http://www.forgemotorsport.co.uk/con...oduct=FMDVBM35 And here's the text stolen from the Forge site: Quote:
