11-21-2023, 07:52 AM | #1 |
Rep 11
Please Help! Sudden loss of clutch
New to the forum and new to the BMW community. Just picked up a 2016 340I X-drive 6MT a week or so ago. Coming from an Audi S5 Sportback, but wanted to get back into a manual AWD.
Last night leaving from a stop going from 1st to 2nd gear (somewhat aggressively) as I let out the clutch it felt almost like I didn't engage 2nd all the and made a "bang" like it popped out of gear. Next the clutch was gone. I have had no slipping or issues and was told it was replaced with a stage 2 or 3 twin disk clutch recently. I have driven manual for 20+ years and never had this happen. The clutch has the normal chatter when disengaged at idle and now continues when pedal is pushed in. Has anyone had this happen. I have not been able to find anything in the search. I was able to get into 2nd and limp to the shop last night since I was less than a mile away. No smells leaks or any other noises when driving. Pedal still feels normal and not on the floor. I did not check any fluids. Hope this is a simple fix before the holidays! Thanks for any feedback! |
11-21-2023, 09:53 AM | #2 | |
46
Rep 85
Turn the car off, put it into 1st gear, MAKE SURE YOU WONT HIT ANYTHING, and push the clutch in and start, if your car moves forward then you gotta take the trans off bc the clutch is not releasing |
11-21-2023, 09:56 AM | #3 |
2475
Rep 1,833
be careful with aggressive 1st to 2nd gear changes, our transmissions are known for those synchros to be weak and can develop a grind there.
i know it’s not related to your issue here but just for future reference
samspiderman312545.50 |
11-21-2023, 10:18 AM | #4 | |
Rep 11
11-21-2023, 10:19 AM | #5 |
Rep 11
11-21-2023, 02:22 PM | #6 |
46
Rep 85
for sure! reverse will also work just fine as long as you have enough space to not slam into someone else, keep in mind youre starting in gear lol, let me know what it does!
11-22-2023, 09:33 AM | #7 |
Rep 11
11-22-2023, 09:35 AM | #8 |
46
Rep 85
11-22-2023, 10:15 AM | #9 | |
Rep 11
I will let you know what they find. Still feel like a spring, clip, or cable let go. It never slipped or made a sound. My wife said it was one of the easiest clutches she has driven. Can a Master Cylinder just give out? |
eluded3064.00 |
11-22-2023, 10:43 AM | #10 |
479
Rep 798
If the hydraulics failed you'd have fluid on the ground or on the firewall by your left foot and the pedal would go right to the floor and not come back. Your brake system shares this fluid as well. So if you're putting that fluid outside of the reservoir you're going to end up eventually losing your brakes.
I don't think it's a throw out bearing either it typically makes a bunch of noise before it goes. They fail in stages, before completely seizing and making the car unusable. You would have known that was on the way out for months, it would have gotten noisier and noiser every time you let the pedal out week to week. To me it sounds more like a broken shift fork or input shaft. Hope not. |
11-22-2023, 10:55 AM | #11 | |
46
Rep 85
B58 parts478.50 |
11-24-2023, 05:19 AM | #13 |
2JZ-GTE
3064
Rep 4,010
Wonder if problem between clutch pedal and clutch. Cable or cylinder
11-24-2023, 06:59 PM | #15 | |
Rep 11
BMW Clutch Kit - LuK 21207603248 BMW Pressure Plate Bolt (Pack of 6) - Genuine BMW 21207548052KT BMW Dual Mass Flywheel - Genuine BMW 21208667195 Thanks again for any help and suggestions! |
11-24-2023, 07:22 PM | #16 |
2475
Rep 1,833
550i clutch does work with xdrive, you pretty much have to run it if you still want to run any sort of a tune. an oem 340 clutch won’t handle much more power over stock.
11-25-2023, 08:42 AM | #17 | |
Rep 11
Basically asking for a parts list for those who have made the switch please. Thanks!! |
11-25-2023, 08:48 AM | #18 | |
2475
Rep 1,833
i haven’t done the clutch replacement myself yet, i want to ride out the stock clutch and then refresh the full clutch and shifter assembly, but i think you need to be past 80k miles to make it worthwhile. ecs has the 550i clutch kit, you can check under kit contents for full list of parts the kit comes with. that’s all you’ll need for the swap: https://www.ecstuning.com/b-genuine-...n/21207603248/
11-29-2023, 04:15 PM | #19 |
Rep 11
Found out the problem. The SPEC Pressure plate had one of the fingers break off, so that's awesome! it mared up the Flywheel as well. I am removing the SPEC 2+ clutch and SPEC single mass aluminum flywheel and putting in the 550I clutch with factory flywheel. Car has 90K and it is to have fun with. Not drag racing, but may try tracking it a couple times.
Wires1657.50 |
11-29-2023, 06:39 PM | #20 |
479
Rep 798
Bummer. Nobody guessed that. Great I just bolted one of those on. That can happen if that side wasn't torqued like the rest. Or otherwise it was uneven somehow..
My 550 clutch lasted 14 months on the stg2+ e50 tune. Don't ever launch it. There was no damage or hotspots or anything like I was expecting, just the pads disappeared quickly. Hope you get better use out of it. It is the way to go if you can get it to last. |
11-30-2023, 07:41 AM | #21 | |
Rep 11
11-30-2023, 07:58 AM | #22 |
479
Rep 798
It was about 12,000 MI. I did an aggressive launch one time. Then a few days later a shift into fifth threw the drivetrain malfunction code. And once that starts it's pretty much it. It came back here and there every so often for a few months, then more and more frequently, then the clutch disc slightly damaged code turns to the clutch disc severely damaged code, and then a few days later it won't hold going up a hill.
