11-07-2023, 06:11 PM | #1 |
Rep 30
Drives: BMW 335i F30
camshaft adjustment gears
I’m replacing my gears on the front of the camshafts. I bought aftermarket and when they arrived they are the same part number. I ordered intake and exhaust and bmw lists different part numbers. Are they really different? They look the same. Also. My original sprockets do not have plastic covers over the springs. Should they? Should I remove the covers? I kind of like the covers because my original springs are interfering withe the cam position sensor.
Thanks Stu |
11-08-2023, 03:01 PM | #2 |
Rep 30
This is why I’m asking about a plastic cover under the pulse wheel.
11-09-2023, 11:09 AM | #3 |
399
Rep 666
Whatever you're doing, DO NOT mix up the intake and the exhaust gears. The two sprockets have different timing variation angles. If you get these wrong, you should see drivability issues. I'm not sure if the variation in the timing window will cause your valves to tap the piston, but I'd would advise you to be very careful on which gear goes on where.
On back of valve gears, you should identify some German words with these 3-letter prefixes to help you figure out which is which: AUX_____ => Exhaust Gear EIN_____=> Intake Gear Both have longer wording, I just don't recall them German words, but with those 3-letter heading that should help you identify it. On some gears that come with plastics, you can often find those markings etched into the plastic. If oil sludge has much filled the etched wording, you'll best get some WD-40 and clean it out to see it. By the way, the timing discs can be interchanged without fail. It's the gears you need to be sure of. And you'll ABSOLUTELY need to use new bolts to torque it all down. Those bolts are TTY (torque-to-yield). Cannot be reused because the engineered properties will differ after their first stretch. You wouldn't want to have done all this work only to let the bolts back out and let wrongly timed valves gangbang your pistons (or vice versa). Good luck, buddy.
2015 X535i - CP Piston, Manley Rod, ACL/King bearings, MILVs VRSF full charge Pipe, Wagner FMIC, Hybrid Turbo, MHD2+ VRSF DP, UR Front/Rear Sway Bars, Eibach springs, Bilstein B6
2015 MINI COOPER - Mahle Pistons, Max Rods, BMS intake, CTS charge pipe, Wagner Intercooler, ByteTronik Tune, VRSF DP 2017 540i - MHD2+, VRSF DP, TU Pump |
Stu Blue Car5.00 Jvac438.00 |
11-09-2023, 01:50 PM | #4 |
Rep 30
Thanks. I’m just waiting for the exhaust gear to arrive. Saturday it is scheduled for delivery. I have my new BMW bolts, that’s the cheapest thing i have ever bought there lol. Hopefully it’s back on the road Sunday.
