11-01-2023, 04:58 PM | #1 |
23
Rep 214
N55 Ps2 EWG Time To Upgrade
Hello Everyone
I hope everyone is fine. So have been pushing 435whp@18psi on 93 octane for months now. The fun has begun to fade now. Looking for some more power to reach atleast 600whp. Stock internals would be fine for now. Current Mods Pure stage 2 DV upgrade AEM.WMI injection kit Phonix intake manifold with 750cc injectors Catless downpipes Resonator delete Planning to run E85 now. There are plenty of options which can be upgraded but here are few i searched. Any additional info would be appreciated. 1 bm3 flex fuel kit 2 lpfp upgrade 3 lift kit Dorsch 4 HPFP upgrade Etc Etc And the list goes on. I have a AIC port injection system laying around but never used it. Will it be of any help? Can someone point me in the right direction. I talked to my fabricator to make bigger exhaust manifold attached with my PS2 and he says it can be done. It would be like attaching a pure750 manifold to ps2.turbo. i have read many people complaing about the restrictiion of the ps2 manifold. Is it worth it? Waiting for your suggestions. Regards. Last edited by Zinia; 11-01-2023 at 07:54 PM.. |
11-02-2023, 03:41 PM | #2 |
4374
Rep 7,622
Turbo - PS2 probably wont reach 600whp. Not sure how much difference the manifold will make, but that's quite high for a PS2.
Fuel - if you already did a PI setup and meth, you should be able to just upgrade LPFP and run PI for the extra fueling. You could throw in upgraded HPFP and lift kit, but it seems a bit redundant if you already have the intake manifold, injector, fuel rails, meth, etc. With that much LPFP demand, you will likely need EKP upgrade as well. Otherwise if you go full DI, the PI setup will be wasted. |
11-03-2023, 10:48 AM | #3 |
BimmerPost Supporting Vendor
24364
Rep 191,163
Before making any purchase, I recommend you talk to your tuner. You will need a custom map.
they will give you a few options on what to buy and how much power to expect
11-03-2023, 11:01 AM | #4 |
23
Rep 214
Hi Mike. I am your very old customer. Started purchasing bms intake all the way upto pure stage 2.
Somebody help me with this project. I emailed almost all of the top 5 tuners. No body is guiding me properly. I have the AIC6 port injection but all of them are saying to buy a motiv or mhd can or something xyz. Why would i waste more money? Got the 750cc injevtors from Xph buy one of them is saying to put EU5 injectors. Feeling sad |
11-03-2023, 01:52 PM | #5 | |
4374
Rep 7,622
11-03-2023, 04:30 PM | #6 | |
23
Rep 214
What mods you running bro? |
11-03-2023, 07:59 PM | #7 | |
4374
Rep 7,622
You need to look at one of the few people who are achieving high 500s to 600whp range. You may have wasted money if you dont pursue a PI setup, since you already bought the intake manifold and injectors for it. |
11-03-2023, 08:38 PM | #8 | |
@lbb_kev
496
Rep 516
The AIC controller you have is outdated. No tuner worth their beans would want to tune with that controller over something like Motiv Reflex that easily integrates with the main tuning platforms for N55s. I would sell the AIC and purchase a Motiv Reflex. Also purchase a low pressure fuel sensor, flex fuel sensor, upgraded LPFP, and EKP to support the LPFPs. Power wise, like what thejeremyman9 mentioned, the PS2 will not get you over the 600WHP goal you want. It could get you close to 570-580whp on E85 at max effort. Maybe you should try to see what that feels like before changing the turbo setup and incurring more cost (moving up to something like the Pure 750). That said, if it's within your budget and you're dead set on 600+whp then you need to upgrade the turbo. Really my main recommendation to you is to not cheap out on the fueling system, which includes the pumps (LPFP) and control (Motiv Reflex and upgraded EKP). A lot of builds live and die by the fueling upgrades (or lack thereof).
Speedtech Stage 3 (8474) | Remus Exhaust | Wagner EVO 3 | XClutch | DS2 + Lift Kit | Nostrum S2 Injectors | TI E5LM | Torqbyte EKP | Intrax 1K2 | SPL | Drexler GT Race Light LSD by limitedslip.de | Schirmer Diff Lift Kit
Full E85 DI-Only 717WHP Flex Fuel tuned by BendCalibration (ECUTek) | Built by SD Garage |
11-04-2023, 10:21 AM | #9 | |
23
Rep 214
Thank you for your detailed reply. I have 3000 usd currently. In which order should i buy the hardware? If i sell the ps2 for say like 1000 usd. So total is 4000usd all i have. Thank you once again. Last edited by Zinia; 11-04-2023 at 10:56 AM.. |
11-04-2023, 07:40 PM | #10 | |
221
Rep 315
you have access to ethanol right? |
11-04-2023, 08:54 PM | #11 | |
23
Rep 214
I have a question. If race fuel is available upto 120 octane than why do people go the E85 way? I have read good reviews about boostane, Race gas ultra etc. Wht not use the octane boosters? I thought the lpfp would work straight out of the box with a tune. That means a newer controller is necessary. The BM3 has options to check for what type of HPFP are you running. Than why is a controller required. Maybe we can go DI only. Upgraded lpfp/hpfp and a tune on top? Kindly guide |
11-04-2023, 10:29 PM | #12 | |
@lbb_kev
496
Rep 516
Octane boosters tend to leave residue that isn't desirable, especially if coats your O2 sensors. LPFP will work straight out of the box. You will need a tune to control the injectors for your port injection. Yes DI only is a nice and clean route. It's also out of your budget if you decide to upgrade your LPFP, EKP, injectors, HPFP and Lift Kit, as well as the labor to install all of those and also the flex fuel kit. If you can make it work then it's certainly a desirable route.
11-05-2023, 05:44 AM | #13 |
23
Rep 214
Ok i have a plan
Lets start with Lpfp 2.5v2 Big boost 3.4 Till than i will use the AIC split second or use upto E30. Later after when i save some money we can go for hpfp wih lift kit. Lastly we can add the reflex plus kit to take over all the control of WMI, flex fuel . Port injection etc. Seems good? |
