BMW E92; Amp Wet, No Start, No Crank
10-31-2023, 11:34 AM | #1 |
Rep 1
09 E-92 Amp got wet; car was running before I located the wet amp; dried out water and amp; now car won't start.
Disconnected negative on battery to reset. Getting locks, lights, instrument panel, radio, time, etc but no crank or start. I'm guessing it could be the starter, but with water intrusion wanted to start at electrical first. Any feedback would be greatly appreciated. Thanks, AB Last edited by abarton26; 10-31-2023 at 11:43 AM.. |
10-31-2023, 02:10 PM | #3 |
746
Rep 1,103
Drives: '01 Z3M, '12 335is, '22 540i
Garage List 2012 BMW 335i [5.25]
2012 BMW 335is [5.00] 2008 Infiniti QX56 [0.00] 1967 Chevrolet Corv ... [10.00] 2001 M Roadster [10.00] 2022 BMW 540i [0.75] 2009 528i [9.50] |
The starters in the N52 motors are a known weakness. Were you getting any symptoms prior to the wet amp? When a starter in my old e91 began acting like low battery, it wasn't long after that the starter died. Hate to throw parts at it without knowing with certainty. Has the starter in that car ever been replaced?
10-31-2023, 02:14 PM | #4 |
17386
Rep 18,774
My E90 took 2 weeks to fully dry out after I dumped 64 ounces of water in the trunk. I disconnected the battery and let the car sit for two weeks. Reconnected the battery, then jumpstarted it. That was 18 months ago. Been fine ever since. Have no technical explanation for it.
10-31-2023, 05:27 PM | #5 | ||
2741
Rep 4,066
How to test for lack of proper voltage to Jumpstart Terminal: 1) Measure Voltage at Jumpstart Terminal under Hood (Red Plastic Cap); 2) Compare with Voltage (in reference to Chassis Ground) at (+) Battery Post. 3) If Voltage measured at Battery Post is significantly GREATER than voltage measured at Jumpstart terminal, then you likely have an issue caused by water at the "Transfer Point" for B+ supply to Jumpstart Terminal, and Starter. You can also test Starter & Starter Solenoid, by "Hotwiring", or applying voltage to a connector in the E-box under the Hood: X6011/1, or Socket #1 of Connector X6011. That is where the Black wire from KL50 of the CAS Module sends Voltage to the Starter Solenoid. If the Solenoid does NOT click, then likely the Starter Solenoid has failed. If the Solenoid clicks, but the Starter does NOT Crank/ Turn the engine, then likely either: (1) the Starter is NOT getting sufficient B+ voltage, (2) the Ground Cable at the Starter is failing, or (3) the Starter itself is defective. While a failing Starter Motor/ Solenoid is the most likely cause of the issue reported by AB in this case, there are TESTS that can be done with proper Diagnostic Software such as INPA or ISTA, to test CAS Terminal Voltages, or to read Fault Codes in CAS Fault Memory (such as A0B4). It would be a shame to take all the time to replace the Starter (after removing the Intake Manifold), only to find you STILL have a "NO Crank" issue that needs proper diagnosis. George |
11-01-2023, 11:50 PM | #7 | |
2741
Rep 4,066
Devil is ALWAYS in the DETAILS. George |
Hoody0071326.50 |
