Help! Rod Bearing Change
09-30-2023, 08:16 PM | #1 |
13
Rep 178
Hi, I replaced my rod bearings. Everything went well however I noticed one of the rod caps did not sit completely flush, the rest are perfect. I torqued it down correctly aswell. I have attached two pictures of the one sitting incorrectly. One picture of one that is perfect. Please help! I’m trying to finish this job asap.
09-30-2023, 10:03 PM | #3 |
13
Rep 178
I’ll try reseating the bearing thanks, the cap is definitely in the correct orientation I double checked and I had marks when I put it in.
10-01-2023, 12:00 AM | #4 |
389
Rep 900
probably bearings, then. make sure that locating tangs didn't get squashed or deformed.
09 328i TiAg 6MT barebones with sport package
10-01-2023, 12:35 AM | #5 |
13
Rep 178
I reseated the bearings and inspected them, even switched them out with bearings from another cylinder and by playing around I was able to get it slightly better but still not perfect like the other cylinders. I’m not sure what to do at this point.
10-01-2023, 03:52 PM | #6 |
389
Rep 900
Does it become like a “one piece” when you tighten the bolts without bearings? Did you tighten it all the way (I.e., 20+90deg+90deg) when you saw it misaligned first? Was it initially like that or only after you got the new bearing shells? It might be possible that after you tighten it slightly offset, split surfaces no longer match each other 100%, some “peaks” got squashed and slightly widened no longer fitting corresponding “valleys”. You might need another rod in the worst case scenario.
10-01-2023, 07:35 PM | #7 |
13
Rep 178
I got it close but still not perfect even without the bearing shells. I did tighten it all the way before and I just noticed it misaligned as I was putting the pan on. I don’t remember if it was like that before touching it. Heres a couple pictures. I’m assuming close enough isn’t good enough. The engine is out of the car and I do have rods from another engine but I’d rather not take it apart. Would I have to get the head machined if I removed it ?
10-01-2023, 08:59 PM | #8 |
487
Rep 482
Drives: 2009 E93 M3 DCT
Did you had fully tightened up the rod bolts while the cap is not seated correctly? If so, you may have damaged the matting surfaces requiring a new connecting rod. I believe that these are cracked forged rods, meaning that the mating surfaces are very rough but they mate perfectly with as a set. If you did not align the cap perfectly with the rod and then tightened down, you most likely damaged the mating surfaces.
10-01-2023, 09:28 PM | #10 |
487
Rep 482
Yes but you will have to take the head off to replace it. And measure the clearances for the rod bearing since you are changing the connecting rod.
10-02-2023, 12:42 AM | #12 | |
389
Rep 900
P.S. don’t put an N54 rod in, it’s different from the n55 rods and probably has a significantly different weight |
10-02-2023, 12:44 AM | #13 |
13
Rep 178
I was thinking that too but having the engine on the stand (it is a used engine). It might be good to take a look inside the cylinder anyways. My rod is from a newer N54 09 this is an 08 it should still be okay?
10-02-2023, 01:13 AM | #14 |
389
Rep 900
as far as I know, late n54 rods are the same as early n54 rods, and all the n54 rods are different from the n55 rods. now with the n55 rods, there were early n55 rods (e series) which are not the same as f series ewg n55 rods even though e series rods got superseded by the ewg f series rods. I'm saying that you'll either need to get an early style e-series rod, or a complete set if you get it from a newer n55. Or I actually might not be quite right and you will need a complete set in either case.
10-04-2023, 03:46 PM | #15 |
13
Rep 178
I discovered an old thread where someone did essentially the same thing. Would It be worth changing out the piston rings ? The engine has 180k kms on it.
