Bimmerpost
4 Series
Technical Topics B48 4-Cylinder Turbo Engine / Drivetrain / Exhaust Modifications When using BM3 to read the fault code, it displays: 10D000
      09-28-2023, 07:26 AM   #1
w752789114
Drives: BMW G20
  [0.00]
Regarding the issue of reading the fault code 10D000 (combustion engine: Torque limitation active)
I have tried flashing ACN, 91, or custom programs, but after driving for a day or two, this fault code appears. I have searched online for a lot of related information, but still cannot resolve it. Has anyone else encountered this issue?
      09-28-2023, 09:59 AM   #2
BLK.G20
BLK.G20's Avatar
216
Drives: 2023 M340 Xdrive, 2023 M3CX
Reach out to PTF. If the car is driving fine, try clearing codes and driving to see if it comes back up.
      09-28-2023, 07:23 PM   #3
w752789114
Drives: BMW G20
  [0.00]
I’ll give it a try,thank you
      11-23-2023, 02:31 PM   #4
Beemertechnik
Beemertechnik's Avatar
Drives: 330i xDrive (G20)
Hey man, I’m experiencing this same problem. What mods have you done to your car? What stage are you currently on and is your car XHP flashed?
      11-23-2023, 03:38 PM   #5
g20_wumbo
g20_wumbo's Avatar
28
Drives: 2019 BMW 330i
2019 BMW 330i  [0.00]
Looks like the torque limit is reached because of the tune. I know that an XHP flash would remove the torque limits and would stop this from happening again. XHP stage 1 should suffice.
      12-10-2023, 10:17 AM   #6
ztech
132
2019 BMW  [0.00]
Yeah but if the ECU is limiting engine torque than it doesn't matter if xHP removes the limit. That's why that 10d000 scares me.
19' 330i G20 E85 Custom Tuned
100-200km/h 11.76 seconds (Racebox GPS)
Full bolt-ons (stock turbo/stock engine)
      12-10-2023, 01:10 PM   #7
g20_wumbo
g20_wumbo's Avatar
28
Hmm, you got a good point there.
      12-12-2023, 10:20 PM   #8
ztech
132
2019 BMW  [0.00]
I'm thinking now that 10d000 is related to the REL FILL LIMIT flag in BM3 data logs. REL FILL LIMIT = 2 indicates "turbocharger protection" likely limiting spool speed. I ran a lower octane map (93) that wasn't REL FILL LIMIT flagged and the power feel much smoother and linear. Make sure your tuner addresses the issue..
g20
