09-26-2023, 04:18 PM | #1 |
BMW obsessed
9587
Rep 10,878
IND | Eventuri G07 X7 M60i Carbon Intake System
Performance Gain: 18-25hp, 15-18ft-lb with up to 30hp peak gain. Max Flow Rates: Stock 774 CFM, Eventuri 900 CFM Introducing our F9X X5M / X6M, G09 XM, and M60i intake. This intake is the result of extensive R&D and testing to improve on the flow path of the stock system. Our system is a complete redesign of the stock airboxes with the aim of reducing pressure loss while increasing the flow rate and keeping inlet temperatures low. With the stock cold air feeds at the front of the car and the turbo inlets facing the rear of the car, the airflow has to negotiate a 180 degrees turn through each airbox resulting in a flow restriction. To overcome this we have introduced an additional cold air feed from the scuttle panel, which results in a more direct flow path to the turbo inlets. The additional feeds allow the intake to have a higher flow rate whilst keeping IATs low and have an additional benefit of de-restricting the sound of the turbos. With the intake openings now facing the cabin, the turbo flutter and pressure release sounds are clearly audible, elevating the driving experience to another level. Application Guide:
The Eventuri G07 X7 M60i Carbon Intake System may be viewed at the following link to our online store: https://ind-distribution.com/product...-intake-system Please contact IND by phone or email for more information or to place your order. 866.963.4520 | info@ind-distribution.com
