09-25-2023, 06:28 PM | #1 |
38
Rep 40
Drives: BMW X5M
2022 X5M Competition Engine Light and Multiple Alerts
I just bought a 2022 X5M Competition with around 4k miles on it 2 weeks ago. Have put 1,000 miles on it and just ran into this issue over the weekend.
Have had alerts that have been popping up periodically that all come on at the same time which put the car into some form of limp mode. There seems to be no rhyme or reason as to when they pop up, sometimes 20 minutes into the drive, other times right when I start the car. Today it came on right after I pushed it real hard getting on the highway. Sometimes I drive 100 miles and no errors pop on at all. Dealer cannot get me in with a loaner for a few weeks so I figured I'd ask here if anyone has experienced anything like this. Errors - Continuous driving possible: 4 wheel drive system - Continuous driving possible: Chassis Stabilization - Drivetrain - Rear axle differential - Reduced driver assistance Thank you guys, |
09-25-2023, 06:51 PM | #2 |
92
Rep 199
Not sure if its relevant to your case but I have seen some other guys having such issues with multiple lights etc and it was related to car battery - weak/dead battery etc.
But since you are saying it happens while you drive then maybe its something different...best thing would be to monitor voltage of battery next morning before turning car or having an ODB2 reader such as Carly would help you to see voltage and other errors related. |
09-25-2023, 07:30 PM | #3 |
5501
Rep 8,833
^^ that was what i was going to say. Cars could have been sitting for months without being driven at the dealer so its highly possible and those codes are consistent with those that had low battery issues.
My suggestion is get a ctek battery trickle charger to fully charge it up with the terminals under the hood Then get a blutooth OBD2 doggle and the Bimmerlink iphone app so you can check for faults as well as battery level. I got this and works on my X5M perfectly https://a.co/d/e38LJRX This is the ctek model I use https://a.co/d/egtNN4g Alan
09-25-2023, 07:30 PM | #4 |
1101
Rep 1,177
Drives: 2024 X5 Comp BGM / Sahkir
Sounds like The battery will likely need to be changed…
10-02-2023, 02:46 PM | #6 | |
38
Rep 40
Drives: BMW X5M
10-06-2023, 02:38 PM | #7 |
64
Rep 116
Most certainly a battery issue. Could be the battery itself, an alternator or some other battery charging issue.
Had the exact same problem on an Audi Q3 last week. New battery resolved it. |
10-09-2023, 10:37 AM | #9 |
38
Rep 40
Drives: BMW X5M
I had to get it towed on Friday due to the throttle not working while I was driving. In the shop now so we will see what happens. Most likely will be trading this in and ordering an M3 comp. If they can fix this in a weeks then Ill keep it.
10-30-2023, 12:13 PM | #10 |
38
Rep 40
Drives: BMW X5M
Update: Dealer believes they have a fix in place. They replaced the gas pedal and said via text that they are "re-wiring something". Dealer said whoever did the wiring prior did some interesting stuff so this could be a nice fix. The gas pedal was replaced before so this will be a repeat of what was done prior. Going into the dealer today and will report back what exactly was done. Should be getting the car back in the coming days at the latest. Can't wait to have this thing back.
10-30-2023, 02:22 PM | #11 |
Flavor of the month
937
Rep 753
Drives: BMW F87 M2C
This got me once recently as well.
Samuel of the Internet
2023 F98 X4M Comp 2023 F95 X5M Comp 2020 F87 M2 Comp |
10-30-2023, 02:23 PM | #12 | |
Flavor of the month
937
Rep 753
Drives: BMW F87 M2C
10-30-2023, 06:48 PM | #13 | |
16
Rep 16
Test drove another x5mc before that. It had chassis stabilisation error. The dealer said it "was nothing" Neither of these sounds like what's happening to you, but it's my experience so far with these codes. |
10-31-2023, 09:31 PM | #14 |
38
Rep 40
Drives: BMW X5M
Update: She's in my hands and working great. They spent 21 hours working on my car. I will be piling on the miles to ensure this fix is permanent. Man I really forgot how powerful this thing is.
I appreciate everyone's value here and hopefully I don't have to deal with this ever again. |
coldpotatosalad15.50 |
