      08-12-2007, 01:15 AM   #1
Carlitos_SS
Drives: 06 G35, 04 TSX, 98 Camaro SS
Anyone else worried about the fuel pump failures???
I was hoping that by now BMW would have solved the high pressure fuel pump problem, but the failures seem to keep popping up on E90post. I sure hope this is resolved before the 1er comes to the States. I know the 1er will be one helluva performance value, but I can't see myself buying a vehicle knowing how high the chances are for it breaking down.
'Los
      08-12-2007, 07:11 AM   #2
inTgr8r
inTgr8r's Avatar
2426
Drives: M2 Comp
Has there been any reported issues with the revised replacement pumps?
I don't recall hearing of any.
This engine is going to be BMWs bread & butter for the foreseeable future.
You can count on them figuring out the fuel pump problem. (& the over heating).
'21 M2C Hockenheim Silver
'18 718 Cayman S Lava Orange (sold)
'13 E92 M3 Santorini Blue (sold)
'07 Z4 M Coupe Alpine White (sold)
      08-13-2007, 07:54 PM   #3
brando1985
Drives:
Worried? Absolutely not.
      08-14-2007, 10:17 AM   #4
vintage42
Drives: 1997 BMW Z3 1.9
Originally Posted by Carlitos_SS View Post
I was hoping that by now BMW would have solved the high pressure fuel pump problem...
Is this only on the 135 which has the higher pressure direct injection (vs the 128 with port injection)?
      08-15-2007, 11:28 PM   #5
Carlitos_SS
I've just noticed several threads on e90post where people are experiencing symptoms of HPFP failure with their replacement pumps and needing their cars serviced, again...
Here's one of several examples:
http://www.e90post.com/forums/showthread.php?t=77664
'Los
      08-16-2007, 11:21 AM   #6
Vornado
A swell fellow
Vornado's Avatar
Drives: Hot air balloon
I eat fuel pumps for breakfast.
      08-31-2007, 03:49 AM   #7
casey.shuff
ShuffDaddy
Drives:
Fuel Pump
My Fuel pump went out after 300 Km, but I have not had a problem since it was replaced.
[SIGPIC][/SIGPIC]
Rolling on the autobahn, 120 Mph every day.
      08-31-2007, 09:07 AM   #8
WolfsburgerMitFries
WolfsburgerMitFries's Avatar
12
Drives: BMW 3er
Yes, regular fuel injection operates around 4-6 bar, direct fuel injection systems operate up to 200 bar. One thing I find funny, Volkswagens 2.0L turbo 4 (which has won numerous awards) has direct injection, but there is no sign of premature fuel pump failure in those cars. I find it odd because neither BMW or VW make fuel pumps, the likely are both buying from the same supplier in Germany like Siemens VDO.
Here's a BMW relevant press realease from Siemens VDO
http://www.siemensvdo.com/press/rele...0604_002_e.htm
For those who don't know, 1 bar is about 14.5 psi. Unless you're Irish.
      08-31-2007, 10:14 AM   #9
Brookside
244
Drives: 2016 228i M-Sport
They did - and if anyone clicks on the e-90 link above you will find that it's a bunch of chuckleheads who are putting low octane fuel (91 min for N54)
and even ethanol mixtures who've experienced trouble with the replacement pump.
C'mon- BMW goes out of its way (decal on interior of fuel-tank lid) to warn all BMW drivers not to use low octane...and then these idiots who've shelled out 40k+ on a 335 pour ethanol mixtures and cheapo gas in the tank.
Unbelievable.
Legally, when this is done the owner/leasee has broken the contract- tho I've only heard of BMW taking the car back (a 335) once from a friend of mine who works in a New Jersey dealership.
So, can we stop with the scares?
      08-31-2007, 12:57 PM   #10
WolfsburgerMitFries
12
Drives: BMW 3er
Unbelievable.
I've noticed that in the midwest, particularly traveling to Chicago, even "top tier" gasolines like Shell have a sticker on ALL the fuel pumps that say "Contains ethanol". Sadly, sometimes alcohol in your gas is simply unavoidable.
Here's a relevant article about "top tier" gasoline for those unfamiliar with the ummm...lets just call it marketing.
http://www.toptiergas.com/
      08-31-2007, 01:13 PM   #11
joelk
joelk's Avatar
37
Drives: Space Gray E90 M3
i plead ignorance. perhaps someone can help me understand. i was under the impression that ethanol additives to gasoline raised the octane of the fuel mixture.
if that's the case, and people driving performance cars need higher octane gas, then why do people look down on using ethanol? does it damage fuel line components in other ways?
thanks for any info!
p.s. from that link above even Top Tier gas is required to have a minimum of 8% ethanol.
      08-31-2007, 01:58 PM   #12
kurichan
Mr. Happy
Drives:
Nope. It's a different additive.
Ethanol is a fuel component that displaces some petrolium based gasoline in the mix. It actually contains less energy per volume than petrolium gasoline.
Yes. It's corrosive to many components that have been used to date, but using ethanol tolerant components in production is not a HUGE challenge. GM and Ford have done it I believe.
      08-31-2007, 02:05 PM   #13
joelk
joelk's Avatar
37
thanks for the explanation but this confuses me a little then
"The standard "blending octane value" for ethanol is about 113. Normally one litre of ethanol blended with 9 litres of petro-gas raises the octane of the 10-litre blend to the next grade level. For instance after blending 9 litres of petro-gas with one litre of ethanol, Regular Unleaded (87 octane) becomes Unleaded Plus (89-90 octane) and Unleaded Plus becomes Premium (91+ octane)."
http://www.gov.mb.ca/est/energy/ethanol/ethanolfaq.html
anyway it's not that important to me ... i just just curious. thanks!
      09-01-2007, 02:19 AM   #14
321
Stay a while and listen...
21
Drives: vr4
How did this slide by?
edit: thought i would add something... Xylene has an octane rating of 117
      09-01-2007, 01:47 PM   #15
kurichan
Mr. Happy
Drives:
Frankly, I'm more worried about basic build quality and the rear suspension.
      09-01-2007, 05:30 PM   #16
WolfsburgerMitFries
12
Drives: BMW 3er
What issues would there be with the rear suspension? From what I understand, its basically the same 5 link IRS as found in the current 3 series. Has that been problematic?
      09-11-2007, 02:28 AM   #17
Carlitos_SS
Unhappy
Here's another one. Freakin' ridiculous. As much as I would like to own a 135 I'm having some serious doubts about the reliability of these pumps. I sure hope BMW does something FAST!
http://www.e90post.com/forums/showthread.php?t=83073
'Los
      09-11-2007, 02:32 AM   #18
Carlitos_SS
I noticed in your info you own a 325. Do those also have High Pressure Fuel Pumps?
'Los
      09-11-2007, 04:19 AM   #19
ichiban
ichiban's Avatar
94
Drives: 08 135i
i'm sure bmw will fix this ... again. but if not, are there any aftermarket options out there?
      09-11-2007, 03:02 PM   #20
321
21
Drives: vr4
I don't think bmw has anything to do with fixing it.. I believe it is in the hands of Siemens AG. Sadly there isn't any other options at this point.
      09-11-2007, 03:15 PM   #21
ibeam81
20
Drives: 2016 EBII M235i, 2004 Acura TL
I was under the impression that the fuel pump issue had already been addressed. Are there still problems with the new pumps? :iono:
      09-23-2007, 03:27 PM   #22
midlife
ocasionally in crisis
midlife's Avatar
52
Drives: '08 335i cabrio
'Los
1/ from what i understand, some of the "replacement pumps" could have been brand new pumps ...but the old design.
2/ also, i understand that the new pump is a bosch, and the older pumps were the siemens.
i am getting my 2008 335 in about 45 days, i am just hoping i will have a new BOSCH HPFP !
my guess is that:
1/ BMW still has the older siemens pumps in stock
maybe they are still using these siemens pumps as replacement pumps
2/ I AM HOPING that all new cars with N54 motors have the new BOSH pump.
anyone out there no for sure of any of my speculations?
Search this Thread:
Advanced Search
1addicts
