08-12-2023, 10:43 AM | #1 |
47
Rep 16
Drives: BMW M135i xDrive
Slight damage on right hand side windscreen rubber
How would a repair or replace this damaged part of the rubber surrounding my windscreen?
08-17-2023, 04:51 AM | #2 |
99
Rep 334
If you can't find a neat way to repair it, then replacing the part may be the best solution. See the attached picture. Looks like you need
02 Drip molding left 04 Clip, drip molding, presumably 10 off, assuming that they don't survive the removal process |
08-19-2023, 09:22 AM | #3 |
1213
Rep 2,924
Replace is the only option if it bothers you. Probably not very expensive. And if you've ever had a windshield replaced you'll see how easy it is. The guys at the glass shop will just grab those with their bare fingers and yank it off.
08-23-2023, 07:35 AM | #4 |
47
Rep 16
Thank you both so much.
