08-10-2023, 02:48 PM | #1 |
Joint Chiefs of Staff
24199
Rep 190,807
NEW DINAN BMW/TOYOTA G2X/G4X/A9X REAR TOE LINKS - Lowest Price + Free Shipping!
AVAILABLE NOW!!!! DINAN BMW/TOYOTA G2X/G4X/A9X REAR TOE LINKS Dinan is pleased to be able to announce a new product offering being added into the catalog; the Dinan Rear Toe Links for the BMW G2x/G4x as well as the Toyota A9x chassis’. Experience the Dinan difference today and never look back! Part Number(s): D280-0025 Application(s): 2022-2023 BMW G42/G43 230i (& xDrive) 2022-2023 BMW G42/G43 M240i (& xDrive) 2019-2023 BMW G20/G21 330i (& xDrive) 2020-2023 BMW G20/G21 M340i (& xDrive) 2021-2023 BMW G22/G23/G26 430i (& xDrive) 2021-2023 BMW G22/G23/G26 M440i (& xDrive) 2019-2023 BMW G29 Z4 30i (& xDrive) 2020-2023 BMW G29 Z4 M40i (& xDrive) 2020-2023 Toyota A90/A91 GR Supra The Quick and Dirty: Replaces the stock rear toe link & rubber bushings with precision machine black-anodized aluminum rods and racing-quality rod ends Dramatically improves vehicle stability during hard cornering Improves response by eliminating the deflection of the rubber bushings Rod-ends are Teflon-lined for quiet operation Rod-ends incorporate left and right hand thread, which allows quick and accurate toe adjustment by simply turning center turnbuckle eliminating the need to struggle with the factory eccentric adjustment Rubber boots protect rod ends from environmental damage for long lasting performance and removes the need for constant cleaning The Story: Dinan's Rear Toe Links add precision and predictability at the limit. The stock rear toe links are built with rubber bushings and a curved forged alloy rod. This design allows the rear wheels to have excessive toe change under hard acceleration and braking. All of this flex in the stock toe links causes the car to be unstable. Dinan stops the flex by replacing the rubber bushings with Teflon coated machined steel rod ends and the OEM curved bar with straight billet aluminum rods, thus adding stability. The Dinan rear toe link also incorporates a hex nut shaped center to aid in the necessary fine adjustment of the toe link that is tough to achieve using the stock link.
https://x-ph.com/sale/ Phone number 702-494-9435 Last edited by mike@x-ph.com; 08-14-2023 at 01:14 PM.. |
08-30-2023, 08:44 AM | #2 |
24199
Rep 190,807
09-20-2023, 08:49 AM | #3 |
24199
Rep 190,807
10-11-2023, 10:14 AM | #4 |
24199
Rep 190,807
11-07-2023, 09:21 AM | #5 |
24199
Rep 190,807
11-07-2023, 11:42 AM | #7 |
24199
Rep 190,807
They are, only 9 left in stock at Dinan
01-10-2024, 10:39 AM | #8 |
24199
Rep 190,807
02-07-2024, 09:22 AM | #9 |
24199
Rep 190,807
03-20-2024, 08:33 AM | #10 |
24199
Rep 190,807
