07-23-2007, 03:09 PM | #1 |
Rep 68
Drives: '08 Mitsubishi Lancer EVO X MR
is LSD needed? even on the race-track?
Can someone explain to me how a (LSD equipped) Z4 "M" coupe, got outperformed (slower lap times) by the heavier, less powerful, Non-LSD 335 Coupe? Seems like the LSD didn't do anything for the Z4 "M" LOL!
I'm glad that BMW didn't give the 135 a LSD. Judging from the performance of the LSD equipped Z4 vs the NON-LSD 335; the money was better off being spent elsewhere. |
07-23-2007, 03:14 PM | #2 |
Unofficial Official "IN"
Rep 138
LSDs are great for high hp cars and especially good for drifting. They are necessary, but can be useful in some applications, such as autocrossing.
07-23-2007, 03:18 PM | #3 |
276
Rep 3,465
Drives: 997.2 GT3, '17 G30
As he said, LSD is very helpful in and out of corners when powering out!! Definitely a handling difference.
07-23-2007, 03:41 PM | #4 | |
Rep 68
But does it (LSD) actually make the car go any faster? I think not. When you have cars without an LSD beating lighter cars with LSD. I start to think that the LSD didn’t do anything for it in regards to speed. |
07-23-2007, 03:54 PM | #5 | |
Rep 98
I bet a 335 w/ LSD would post an even faster lap time... and a Z4M with an open diff would post a slower time. |
07-23-2007, 05:37 PM | #7 |
Rep 138
No it wont, can it make you push your car a little more in an autoX event, yes. If you know how to use it, then you can use an LSD to your advantage. It wont make your car reach a speed faster. All it is.... its a basic power converter. It switches the power from the wheel that is breaking loose to the wheel that has grip, potentially preventing understeer. Its not necessary for all cars. If you have a lead foot, well it wont help you very much.
07-23-2007, 06:13 PM | #8 |
28
Rep 1,035
Anything that helps put more traction to the ground when there is ample power or cornering force to break traction will help "reach a speed" faster. (whatever that means)
Put simply, an LSD will make any given car faster on the track because you're able to translate engine power into forward motion as opposed to burnt rubber. |
07-23-2007, 06:35 PM | #9 |
18
Rep 164
I doubt the MZ4 is doing slower times than the 335i, maybe in the wet where that car is really tail happy ; even on the dry it is. The MZ4 is lighter and has more power not faster than the 335i on a track.
I think all BMWs should have an LSD, 15 years ago it used to be included not only in the M models but also cars with the sport package (i.e. 325is) the car behaves a lot better in the corners. Plus you can do awesome doughnuts |
07-23-2007, 06:45 PM | #10 |
2146
Rep 10,176
Two different drivers, and no word on track temps/conditions. 'Nuf said. The stock MZ4 would do damage to the stock 335i on the track with identical conditions.
The MZ4 has LSD and M suspension, plus is a lighter, more tossable car. Don't be glad the 135i doesn't have one. I just put a locking diff in my car, and took seconds off autocross runs in the exact same car/tires/suspension. |
07-23-2007, 06:49 PM | #11 | |
14
Rep 808
And why would you be GLAD that an LSD is not offered even as an option? You don't have to get one, but that doesn't mean that no one should be able to. |
07-23-2007, 06:51 PM | #12 |
2857
Rep 2,750
Drives: 2020 M4 ZCP / 2023 X3 M40i
A LSD equipped car will almost always be faster than a identical non LSD equipped car. I think Spoonie is referring to the recent Car & Driver article where they brought a lot of different cars to a track including the 335i and Z4 M. Car & Driver said that the main reason why the Z4 M beat the 335i on the track is because the 335i is better balanced than the Z4 M.
07-23-2007, 08:08 PM | #13 | |
17
Rep 524
LSD is absolutely vital to an enjoyable driving experience in a high performance sportscar (just because a 335i is fast without one doesn't mean it wouldn't be faster and more FUN to drive with one). It was deleted for only one reason, to keep the 135i slower than more expensive BMW M models. Porsche does the same thing with its Cayman. It's shameful! |
07-23-2007, 10:12 PM | #14 | |
Zoom Zoom
38
Rep 1,069
07-24-2007, 12:14 AM | #15 | |
Rep 138
07-24-2007, 12:32 AM | #16 |
37
Rep 582
Here is a great description of what a proper LSD can do for you. Straight from the Quaife site.
http://www.quaifeamerica.com/differentials/diffs.htm " The Quaife Differential powers both drive wheels under nearly all conditions, instead of just one. With an ordinary open differential, standard on most cars, a lot of precious power is wasted during wheelspin under acceleration. This happens because the open differential shifts power to the wheel with less grip (along the path of least resistance). The Quaife, however, does just the opposite. It senses which wheel has the better grip, and biases the power to that wheel. It does this smoothly and constantly, and without ever completely removing power from the other wheel. In drag-race style, straight-line acceleration runs, this results in a close to ideal 50/50 power split to both drive wheels, resulting in essentially twice the grip of an ordinary differential (they don't call open diffs "peglegs" for nothing). In cornering, while accelerating out of a turn, the Quaife biases power to the outside wheel, reducing inside-wheel spin. This allows the driver to begin accelerating earlier, exiting the corner at a higher speed " That last bit means the car is more fun w/ and LSD if you like to drive hard. -Mahlzeit |
07-24-2007, 02:11 AM | #17 | |
29
Rep 236
Drives: people crazy
MPower and Mahlzeit, thanks for those posts. Hopefully it helped to open some eyes. |
07-24-2007, 08:57 AM | #18 |
Santa Fe Concorso
103
Rep 2,984
I have nothing to add except agreement with MPower and Mahlzeit. The OP obviuosly has not owned a car with with LSD (or driven it hard enough to see the benefit).
Santa Fe Concorso - The Southwest's Premier Automotive Gathering.
07-24-2007, 09:06 AM | #19 |
Rep 68
07-24-2007, 09:24 AM | #20 |
14
Rep 808
Oped diff will send more power to the wheel that is slipping. This will further reduce the grip on that wheel, thereby reducing the total amount of traction available to the car. So yeah, you CAN get more traction from LSD in many cases.
07-24-2007, 09:41 AM | #21 |
Rep 138
How is it so hard to understand that it switches power from the wheel that slips to the wheel that grips temporarily until it sense no slipping.
