Rust status from everyone
08-09-2023, 01:25 PM | #1 |
1558
Rep 3,239
Hey guys, 1 series owner here and looking to go down to one car which means driving the 1er for the first time all year long.
How has everyone’s car held up now that the platform is at most 18 years old. I have had my 128i for 11 years now with 82k miles and wondering how many more years I can get out of it before it turns into swiss cheese from the rust.
2012 BMW 128i 6MT Deep Sea Blue Metallic
08-09-2023, 02:04 PM | #2 |
1007
Rep 2,243
Drives: 2007 328i / 2014 M235i
Zero rust, the body is amazing on these E90 cars and I drive in the winter. I wax the car once per year
The rear subframes rust so I wire brushed it, Used rust converter and then greased it |
08-09-2023, 02:08 PM | #3 |
189
Rep 174
Here in MN I don't see cars made in that era with body rust unless it was poorly repaired at somepoint. It will make working underneath the car a pain. (Speaking from experience) Suspension, brakes and so on
08-09-2023, 02:11 PM | #4 |
Art Collector
2427
Rep 3,450
I think in general, with exception of rear subframe, the Exx cars hold up well from rust.
That said, I have a spot appearing on front fender and I think another small one somewhere else. My hood is fucked in one spot on the leading edge but I *think* that’s because the PO was in a fender bender and there may have been some paintwork done. Not certain as I’d expect a bent hood would be easier to replace entirely, but that’s my theory. Overall they hold up really well. I think my case is somewhat of an exception.
When I'm dead, just throw me in the trash.
08-09-2023, 02:28 PM | #5 | |
1453
Rep 2,135
The body panels on E9x hold up very well relative to other German cousins (VAG group cars) and E46 generation. |
08-09-2023, 03:15 PM | #6 |
74
Rep 249
Mine is just over 17 years old and used as a daily driver in the Northeast. Some rust on the rear subframe, but nothing alarming. I'm thinking its good for at least another 5 years. Body is great. I tried to get it washed after every snow fall -- but no grease or paint treatment of the subframe. The oil pan gasket has been leaking for about 10 years -- so maybe that has helped.
08-10-2023, 11:47 AM | #7 |
1007
Rep 2,243
The key is catching the rear subframe rust before it gets bad. After you do rust conversion I coated with marine grease which will not wash off. Where I could not access I sprayed with rust check.
There was no serious corrosion as I caught it early. If you don’t treat the subframe it will need replacement in the rust belt. Interesting fact that my M235i uses a steel front subframe so it was double the work! |
08-11-2023, 12:04 AM | #8 |
Rep 5
My son's 2006 is parked outside all the time, and it doesn't have any rust on the body. The steering tie rods were a completely different story. The rust fused those parts together.
StradaRedlands4964.00 |
08-11-2023, 02:17 AM | #9 | |
2422
Rep 1,770
Drives: Bmw 330i and Bmw 328i
Efthreeoh17376.50 |
08-11-2023, 10:33 AM | #10 | |
2422
Rep 1,770
08-11-2023, 10:49 AM | #11 |
1558
Rep 3,239
Thanks everyone this makes me feel better about eventually driving in the winter!
Edit: I like the idea of getting a used subframe and I think I will keep it in the basement.
2one3E902422.00 |
08-11-2023, 12:19 PM | #12 | |
2422
Rep 1,770
08-11-2023, 12:49 PM | #13 |
3060
Rep 3,913
Rusty rear subframe (but not terrible yet), and some signs of rust under the underseal around the rear subframe too. Bolt on steel parts like the front v-brace are pretty rusty too.
2007 e91, 160k miles. Had a bit of rodent damage in the last year, but thankfully (I think!) nothing more major than the injector leak off line (chewed to the threads, but didn't leak), bleed nipple covers, some nibbles at coolant hoses which I'll replace sometime. I tried eucalyptus oil, which they didn't like, but it didn't make them leave. Got a sound/light deterrer under the bonnet now, though I didn't get around to it until after the fact. Trapped 2 mice with a spring trap, and that was the end of it really. |
08-11-2023, 03:49 PM | #14 |
180
Rep 115
06' 325i.
Rust nowhere except rear subframe and inside the rear wheel hubs. A little surprised actually. I am in Virginia but cars history has it in Illinois when new. |
08-12-2023, 11:19 PM | #15 |
e91Owner
425
Rep 1,129
Both my 2010 e60 and 2011 e91 are southern cars, so as you’d expect, little to no corrosion on all but high temperature parts. Strangely, though, last year I had to replace a rear axle on the e60 (x-drive) and the axle nut had turned to dust. That $1 part turned into a much more costly and time-consuming repair as I had to replace the entire knuckle just to remove the axle. If I could turn back the clock, I would have just unstaked the nuts and replaced them at intervals.
In any case, something to keep an eye on, especially if you’re driving in a more corrosive environment. |
08-13-2023, 02:31 AM | #16 |
3060
Rep 3,913
My solution for the rusty rear subframe problem will probably be to fit an M3 one. I'll need custom/adjustable toe arms, but everything else will bolt in fine. The M3 frames look far less susceptible to rust, to me; almost entirely tubular construction. Hopefully I can pick one up cheap sometime
08-14-2023, 01:13 PM | #17 |
20
Rep 36
I just recently bought a southern 2011 335d, but I live in the rust belt. I also apply fluid film undercoating professionally. Glad I found this thread, I'll be spending extra time with the cavity wand inside the rear subframe!
09-06-2023, 02:19 AM | #18 | |
Rep 4
Tambohamilton3059.50 |
09-06-2023, 08:20 AM | #19 |
Chief Executive
303
Rep 2,889
Drives: 2008 335xi 6spd Coupe
139k miles in Boston, 15 years young.
I had a small spot of rust on a rear fender, and both my front and rear subframes were rusty. The latter were replaced with used units that was treated with POR15. |
09-06-2023, 07:43 PM | #20 |
654
Rep 815
Rust on the lift gate on my 230K 2008 E91.
It's pretty terminal for the part, but apparently also pretty common. And this after parking mostly indoors for the 13 years that I've had the car. Fortunately, I've found a replacement Southern part in the proper color for cheap. This is my winter project. That said, having something this rusty on my car...where I can poke off pieces and hear/see them fall off...is a bit disconcerting. |
Mike K322.00 |
09-07-2023, 11:50 AM | #22 |
654
Rep 815
