      07-08-2007, 12:54 PM   #1
Big Red One
Drives:
N52 Aftermarket Modifications?
As I understand it, the 230hp N52 in the 128i (and 328i) is essentially the same engine that produced 215hp in the E90 325i and 255hp in the E90 330i. apparently it's simply a software change that is responsible for the changes in horsepower.
Anyone know of aftermarket options for getting more power out of the N52 in the 128i?
      07-09-2007, 11:18 AM   #2
335i=:)
27
Drives: 335i sedan-blk/blk-Poplar
Originally Posted by jrsites View Post
I know this section of the board is N54 specific, but being as I have an engine question, this probably still belongs in here more than it does in the other sections.
I remember seeing a "chip" over at e90post.com for the 325i that gave it nearly 330i power. I would imagine there is one for the 328 to get it to at least 245 hp, then intake and exhaust should get you to about 260hp. But that's about it. The engine reaches it's peak hp at 6600 rpm I believe so not much use in a raised rev limiter.
But if your going to spend around 2k for all those things, you'd be much better off buying the 135i. Have you driven a 335i? Go drive one. I've have mine for 8months now. It's a beast. And, it's getting great track time's, right there with the e46 m3 and rs4. The oner with better brakes, lighter, etc. will be great. Plus you get the m-springs.
      03-31-2008, 06:05 PM   #3
Brandon26pdx
28
Drives: 2011 135i
The N52 has been rated as high as 268 or 272 hp in stock form, depending on what source you're checking. (In the X3 and some other different models.)
Theres defintely more power to be had.
      03-31-2008, 10:26 PM   #4
mikeo
Santa Fe Concorso
mikeo's Avatar
103
Drives: '11 M-sport 328i, '13 X1 28i
Originally Posted by Big Red One View Post
As I understand it, the 230hp N52 in the 128i (and 328i) is essentially the same engine that produced 215hp in the E90 325i and 255hp in the E90 330i. apparently it's simply a software change that is responsible for the changes in horsepower...
In addition, the e90 330i has a three-stage intake manifold as opposed to the 128/328 single-stage manifold.
      09-12-2008, 03:41 PM   #5
ModBargains.com
475
Drives: JB E92 335i
Well at this point, getting the basic performance parts like intakes, exhausts, performance chips (if it exists), and lighter exterior will probably help.
      09-12-2008, 03:52 PM   #6
modbargains
modbargains's Avatar
168
Drives: 08 E90 335i & 01 Toyota Avalon
As James already mentioned above, just wanted to ad the addition of light weight wheels and suspension upgrades to reduce unsprung weight and rear squat then starting from a dig.
      08-19-2010, 02:22 PM   #7
3002 tii
3002 tii's Avatar
2272
Drives: Z4 M, X5, GX460
best way to get the 330i numbers is to upgrade to 330i components which is the 3 stage intake manifold as someone else mentioned. that plus software and you're good to go. intake and exhaust will have minimal effects.
Follow for latest mods
      08-19-2010, 07:52 PM   #8
Evice
Evice's Avatar
193
Drives: E92M3
Thanks for reviving this topic after almost 2 years
      08-19-2010, 11:43 PM   #9
Lucky1
640
Drives: '08 128i Coupe SGM 6MT
Is the 3 stage intake manifold from the 330i a drop-in component or do other modifications have to be made to accomodate? Any ideas on the effect it has on noise? I would think as you increase the throttle it would give a deeper throatier sound which I really am not interested in.
And as for the software, who supplies this?
      08-19-2010, 11:49 PM   #10
Lucky1
640
Found this link that has some details on guys trying to do a 325i conversion to 330i with the 3-stage intake manifold and some ECU reprogramming. Haven't read the whole thing yet to see their results; will do later and report back. Here it is for anyone who is interested:
http://www.e90post.com/forums/showthread.php?t=37444
      08-20-2010, 08:37 AM   #11
tgxmike
tgxmike's Avatar
18
Drives: '21 M2C 6MT, '21 Charger Scat
2021 BMW M2  [0.00]
The part number for the 330i intake is the same as the N51 intake. so yes it will fit. But I believe the rest of the intake needs to be modified.
As above you can order the 128i N51 intake, but no software supplier exists. Closest thing is a BMS powerbox
In short, If you add a exhaust and intake to the N51, you get the most you can from the 128i. and the BMS PBX is usless at that point. To the best of my knowledge no one make a software upgrade that improve over the modification.
So I see 2 possibilities.
CAI + exhaust...... or Powerbox, but NOT both
http://www.1addicts.com/forums/showt...highlight=128i
http://www.1addicts.com/forums/showt...t=N51+powerbox
      10-20-2010, 07:38 PM   #12
Ox
Ox's Avatar
Drives: 2013 BMW 135is
Supercharger
I was wondering if anyone like Eaton makes a Supercharger made for the 128i? I like the 135i performance but think Turbos suck, are problematic and will eventually fail on you. Didn't BMW issue a recall on their turbos?
Ox
Previous Cars: 1987 325, 1999 323is, 2002 Z3, 2002 325ci, 2006 Cooper S, 2011 128i, 2013 128i
Current Car: 2013 135is
      11-07-2010, 11:13 PM   #13
strati1
30
Drives: a slow car fast
is there a scoop kit for the 128?
      11-14-2010, 10:38 PM   #14
leesat
samuray
Drives: M235i
2014 M235i  [0.00]
I think there is scoop kit but it won't work on 128i.
      12-12-2010, 02:05 PM   #15
cse73
cse73's Avatar
Spain
Drives: 125i coupe
Hi there;
In Europe; there are some tuners to reprogram the ecu, get power numbers like of 130i/330 i
In Belgium
http://www.shiftech.be/
In Germany
http://www.ds-motorsport.de/bmw-tuning/1er.html
Greetings
      12-12-2010, 08:19 PM   #16
strati1
30
I looked it up the afe scoops fit both 128 and 135. gains of 7-10 hp @ 70mph. Pretty good for 90 bucks.
      12-13-2010, 09:19 AM   #17
Alex_bm
175
Drives: Giulia QV
It might be 7-10 hp for 135. What about that gains for 128?
      12-13-2010, 09:25 AM   #18
Evice
Evice's Avatar
193
Drives: E92M3
you are not going to get 7-10 HP with scoops. It is wrong to even suggest that..
      12-14-2010, 12:20 AM   #19
strati1
30
thats the CLAIM not the dyno results. ill let you know the real gains when i install them
      12-14-2010, 01:19 AM   #20
Yvette
759
Drives: M
In couple years, I am sure there will be more market in performance for N52.
      12-14-2010, 09:13 PM   #21
strati1
30
Search this Thread:
Advanced Search
1addicts
