2010 2011 BMW 5 Series Forum F10 Dreaded Drivetrain Warning on a 2016 F10 with a Sad Engine |
08-02-2023, 03:45 PM | #1 |
20
Rep 51
It is much more enjoyable to read the posts rather than to create them with issues. My 2016 528 which is currently at 61k miles and as I was driving it today out of my neighborhood for the first time in a couple months and aggressively, yet gently, pressing my foot to against the gas pedal merge into traffic...it stuttered, kicked, dry-heaved (twice I think) and then finally dinged at me and said Drivetrain malfunction: Drive moderately. Maximum drivetrain output not available
Had an appointment so drove about 10 miles and it really rumbled the slower I was and the lower RPMs. I tried it in Eco mode, not different, in fact worse, like having the same issue if the care was a Hugo. I made it to the appointment and on the way home went to my paddle shifters which seems a bit better to help hear and feel the engine really struggles 1-3 RPM and not as bad, but still noticeable above 5. driving in M1-6 moder with paddle shifters made it bearable as just using drive, ther engine really struggles to get going, like is in 6th gear or something History of Repair (only one) 2019 at around 54000 miles Last major service: Valve cover initially where the other stuff was found and 80% covered under a class action with BMW valve cover gasket replaced -EuroEnvy AutoWerks Timing chain - BMW Dealership (Class action around some timing clips) engine mounts (both sides) - BMW Dealership temp sensor - BMW Dealership |
08-02-2023, 09:31 PM | #2 |
5020
Rep 3,072
Drives: 2006 BMW 330i MT
Garage List 2006 BMW 330i [8.21]
2009 BMW 328i Touri ... [7.90] 2013 BMW X5 35i [7.63] 2011 BMW 528i [8.75] 2006 Mazda3 [5.50] |
It's probably not the timing chain or guides, so that's good news! Post up what happened when you get the diagnosis!
08-16-2023, 11:24 AM | #4 |
20
Rep 51
Ok, so the diagnoses is one of the ignition coils was bad, so I am having all 4 replaced at around $450 by my trusted guy who just told me he is moving to alaska......oh well, at least I can get this thing fixed and sold before it cost more.....
08-18-2023, 11:45 PM | #5 |
1780
Rep 441
Drives: 2016 F10 BMW 535i M Sport
Ignition Coils are quite easy to replace even on the N20! I would suggest to replace the Spark plugs and all 4 coil packs at once.
