      07-04-2007, 05:41 PM   #1
replicat
23
Drives: 40MPG
Unofficial Weight
Hey guys im new here to the forums and just wanted to share some cool info I found out.
On the BMW world website if you go to the mini site and click one of the 6 different areas you get to one that speaks of dynamics and such.
It says that the cars has a power to weight ratio of 5.1kg/hp which = 11.2lbs/hp.
If you take the cars rated hp (300) and multiply it by either lbs or kg you get 3360lbs or 1530kgs.
This is not to shabby of a number to have assuming that this is a curb weight. It bests the curb weight of the 335i coupe, by 211 lbs!!
Anywho I just wanted to share this info in case anybody was interested.
:headbang: Pete.
      07-04-2007, 05:49 PM   #2
danp
Drives:
Hi, weight has been mentioned in other threads...but it's a little more than that unfortunately.
Believe it's rated at 306hp (well in Europe it is), which means we have just over 1560kg (which was mentioned in a spec sheet).
1560kg does however = 3439 pounds, so 120 or so less than the 335i
      07-04-2007, 06:04 PM   #3
replicat
23
Drives: 40MPG
Aww shite! NM then. I wonder why they gave this ratio on the site...
Also I just found the thread...and something doesnt match up...there is no way that the car can be so heavy compared to the 5 doors hatch..it just doesnt make sense...there has to be a mix-up/mis-calc between the different measurment systems...
      07-04-2007, 06:20 PM   #4
BForbes
Moderator
BForbes's Avatar
Bahamas
557
Drives: BSM 135i/AW E90 M3
yesir...something is sketchy. The Devil is in the Details though. We'll see when a magazine gets their hands on one. There is speculation that BMWs unladen weight includes 75kg for the driver and 90% fuel.
- 04 Honda S2000(gone)
      07-04-2007, 06:28 PM   #5
replicat
23
Drives: 40MPG
I just read through the thread, and went to the various BMW sites and found that the weight you stated is unladen weight and not curb weight. (Includes some weight)
The E60 M5's US weight (curb weight is 4012 = 1824 )
The E60 M5's EU weight is (unladen weight 4081 = 1855
The difference between the two M5's is 69lbs.
The differnece between my weight guess (most likely the curb weight 3360)
& your weight guess (unladen? 3439) is 79lbs.
So I think that the official curb weight (the only weight that matters) will be 3360 give or take 10 lbs.
      07-04-2007, 06:44 PM   #6
BForbes
Moderator
BForbes's Avatar
Bahamas
557
I have no problems with 3300 pounds and I'm coming from a 2800lb roadster. If Honda wanted to make a coupe out of my car, it'll weigh about 3200 pounds and it wouldnt be a twin-turbo.
      07-04-2007, 06:55 PM   #7
replicat
23
Drives: 40MPG
S2000 is hands down the greatest car I have ever driven..a true drivers car...I even made a 4 page report on it once...
PS. The E46 M3 is is 3415 and handles like a dream and a half from factory so if the 1 weighs less, I think that some KWV3's and some H&R sways will make for a perfect track package. That and some stickier rubber, to do away with the awful factory run flats.
      07-04-2007, 07:10 PM   #8
BForbes
Moderator
BForbes's Avatar
Bahamas
557
Thanks man, I agree. Revving to 8200 is might fun. The 99-03 went to 9,000 rpms as you know. If Honda made a replacement soon enough I would sooo be into that. You know whats ironic? On the official s2k site, I would say I've seen at least 30 guys switch over to the 335i's. Some kept their s2k also. Its all about how the cars communicate with you. I'm sure you understand better than anybody else on this site what shoes this 1 coupe has to fill for me. No worries, I'll burn away those run-flats quick to reduce the weight and have better tires. :headbang:
Btw, there is another s2k driver on here that lurks. He's posted some 1addicts pics on the S2Kforums..
      07-05-2007, 03:50 AM   #9
danp
Drives:
I don't mean to be rude but I'm sure some of you guys (one shots2k ?) have read the other posts on weight...
YES - THE 1560KG DOES INCLUDE 68KG DRIVER, 7KG LUGGAGE, 90% FULL FUEL TANK.
SO UNLADEN WEIGHT MEANS YOU TAKE OFF ABOUT 115KG, SO WE HAVE 1445KG.
CONVERT THAT TO POUNDS (I'LL EVEN DO THE MATH!) = 3185 LBS UNLADEN.
CAN I MAKE IT ANY CLEARER FOR YOU GUYS ?!
      07-05-2007, 06:43 AM   #10
BForbes
Moderator
BForbes's Avatar
Bahamas
557
Hold the phone there danp. You also added 40kg of fuel to the 75kg for the weight of the driver and luggage??
      07-05-2007, 06:57 AM   #11
danp
Drives:
90% of a 53 litre tank = 47.7 litres
47.7 * 0.72 (specific gravity of petrol) = 34.3KG (so I was abt 6Kg out)
Lets call it a round 1450kg
1 450 kilogram = 3 196.702 801 681 lb, lbs
pretty sure that's correct!
      07-05-2007, 07:30 AM   #12
BForbes
Moderator
BForbes's Avatar
Bahamas
557
Its beyond me why bmw wont just say it has a 3200 pound curb weight. They'll make it look 3400lbs from a quick glance at there specs... Ughh. Thanks Dan.
      07-05-2007, 07:31 AM   #13
TerpENME
Drives:
Sounds good to me. My heiffer GTI weighs about 3300 lbs and feels quick with 100 less hp
      07-05-2007, 08:18 AM   #14
danp
Drives:
UK MkV GTI works out at 1320kg (2910 pounds), plus 19kg for DSG...suspect the US one is also a fair bit less than a 135i.
(US tech specs don't mention weight)
      07-05-2007, 08:42 AM   #15
Propagator
14
Drives: 2011 328i LMB 6MT
As I have mentioned in the other thread, the US curb weight INCLUDES A FULL TANK OF GAS. So to compare with other vehicles sold in the US, you need to subtract the driver and luggage, but not the gas. In fact, you have to add a few lbs for 10% gas.
My last guess was ~150lbs subtraction from EU1 to US curb.
      07-05-2007, 11:22 AM   #16
eMINI
Drives:
1560 kg = 3439 lb - 150 = 3289 lb
Or 1560 + 4 kg (to top off fuel tank) - 75 kg (for driver/cargo) = 1489 kg = 3283 lb
So, if we call it 3300 lb curb weight we won't be far off. Of course we still won't know how the sample car was equipped vs. stripped. But it gets us in the ball park.
BTW, a quick conversation with my dealer today confirmed something we'd all been thinking and that's that BMW goes to more trouble and expense to remove weight from the larger, more up-market cars than the smaller, more entry-level cars. That's why a 5 is barely heavier than a 3, and a 3 is barely heavier than a 1. It is what it is.
2010 135i Coupe | Black Sapphire Metallic | Red Leather | Poplar Grey Wood Trim | 6MT | Premium pack | M Sport pack | Heated Seats | HK Premium sound | USB | Smartphone integration | Automatic high beams
      07-05-2007, 01:45 PM   #17
Propagator
14
^^ Makes perfect sense.
      07-05-2007, 02:24 PM   #18
greg964
Drives:
US spec cars invariably weigh more than EU versions due to more standard equipment and safety regs. I will be shocked if the US 135i weighs less than 3300 lbs. I would not even be suprised if it approached 3400 lbs. IMO that sort of mass makes comparisons to the 2002 a bit of a joke. Christ the US E28 M5 only weighed 3300 lbs.
      07-05-2007, 05:40 PM   #19
eMINI
Drives:
IMO the comparisons are mostly just marketing. It's been said on hear before by another, but the 1-series is just another great new car from BMW. This one's smaller than most and quite powerful. It's aimed at those of us who want a smaller, more nimble BMW with more feel and less wizardry. Like every other BMW, it has pros and cons.
Is it the spirtual successor to the 2002? In some ways, yes. In other ways, no. Makes no difference to me. I just want it to have that special quality that makes me want to invent reasons to get in the car and go for a spin... again.
PS. Great first post & welcome!
      07-05-2007, 05:51 PM   #20
replicat
23
Drives: 40MPG
Glad we got that all squared away. But all in all 3300 lbs better be a maxed out curb weight and I will be happy...
PS. This forum is so grown up, no flaming or anything. Good to see that we're all a bunch of happy campers..great discussions ladies and gents.
-Pete
      07-05-2007, 06:07 PM   #21
BForbes
Moderator
BForbes's Avatar
Bahamas
557
-Pete
Oh we had a few bad seeds, they'll pop in to ruin the moment just for fun but they've been gone for a while :headbang:
      07-05-2007, 06:50 PM   #22
lanman
Drives:
Just read through this thread...I went from a 2003 S2000 to my current M3. I loved my S2000, quite possibly my favorite car i've ever owned. I have considered more than once to buy another one. Problem is the space and practicality...I think the 135 will be a great balance of room to stretch and awesome driving dynamics.
1addicts
