Creaking noise rear wheel
06-26-2023, 07:33 PM | #1 |
Rep 4
Hi all,
I have a 2011 335i n55 and can’t figure out this rear creaking coming from the rear passenger wheel https://youtube.com/shorts/aKYHS1Hq70U?feature=share I have pretty run out of ideas at this point and looking for help. The noise only happens when applying the brakes and occurs at any speed. The brakes can be hot or cold and it makes the noise. When accelerating or decelerating there is no noise. Applying the hand brake while the noise is present does not affect the noise. The following has been done: New rotors New pads New parking brake shoes and springs New shocks New trailing arm bushings New roll over strut bushing New stabilizer links New control arms Rebuilt Caliper Rebuilt cv axle New bearing Changed diff fluid Checked all subframe bushings and all are okay Tried different wheels and same noise The noise is only present at the rear passenger wheel. Driver side rear wheel is fine. Would love some other suggestions. Thanks in advance for the help! |
